Wing Window Replacement?
Old Nov 8, 2010 | 11:10 AM
bio-d's Avatar
bio-d
Question Wing Window Replacement?
Any advice on replacing the driver's side wing window on my 87 f250?
Thanks,
Mike
Old Nov 8, 2010 | 11:25 AM
1988FordBeast's Avatar
1988FordBeast
patience, and make sure ALL the bolts/screws out
Old Nov 8, 2010 | 03:30 PM
bio-d's Avatar
bio-d
So its just a matter of undoing the door panel? etc.
A mechanic friend said it comes out as a unit.
Mike
Old Nov 8, 2010 | 05:03 PM
greywynd's Avatar
greywynd
Door panel comes off. Larger window comes out first, then the vent window, and the frame (which includes the front 'rail' for the large window) comes out.
To get each one out there are bolts and screws in various places, also some of the seals hook together and other fun things. Take your time, you'll get there.
Old Nov 8, 2010 | 08:44 PM
starmilt's Avatar
starmilt
IIRC there is a screw kinda hidden in the window channel for the wing glass.
It also helps to have the proper tool for the clips on the door panel.
They are plastic so you will probably want to replace at least some of them.
Old Nov 9, 2010 | 10:45 AM
bio-d's Avatar
bio-d
Thanks all,
It was much easier than I expected, two screws on the top and one bolt
on the side. I didn't have to remove the big window. $30 at the junk yard instead of $130 at the window shop.
Mike
77megacab
34
Feb 12, 2021 11:33 AM
bstephen33
'80-'86 FAQs (Frequently Asked Questions)
Apr 5, 2019 01:12 PM
Tuna Maniac
Mar 6, 2017 02:32 AM
lefty1953
Feb 22, 2017 10:50 AM
hivoltj
Aug 24, 2016 11:54 AM
