Rear Caliper
Old Nov 8, 2010 | 07:50 AM
EMC V10 X's Avatar
EMC V10 X
Question Rear Caliper
I have a 2001 Excursion, and the drivers rear caliper is leaking. Would you recomend a rebuilt one from a parts house? Or rebuilding it? Rebuild kit is only 17 bucks. Also the other side? It isnt leaking yet, and shows no issues, rebuild? replace?
Old Nov 8, 2010 | 10:12 AM
wallz's Avatar
wallz
If you have the time why not rebuild. The only diff is doing it yourself, or paying a tad more for rebuilt.
The calipers are fine to replace on one side. I just replaced one of my back ones last week. When taking off the old one take apart the brake line just past the rubber hose, and then do the work on the bench. I had to learn the hard way with more fluid all over and a broken banjo bolt.
It is the rotors if you need to replace one you replace both.
Old Nov 8, 2010 | 11:19 AM
perryg114's Avatar
perryg114
Pop out the pistons and see what the bore looks like. If it is not pitted then rebuild it. If it is toast get a quality rebuild like Bendix. I took some rebuilds off my old F350 because it was pulling to the left. Come to find out that the rebuilder had sandblasted the inside of the bores till it looked like rough cast iron. The Bendix calipers were good quality and they came with new pistons as well. I would pop the pistons on rebuilds just to make sure they are good rebuilds.
Perry
Old Nov 9, 2010 | 05:50 AM
EMC V10 X's Avatar
EMC V10 X
Well, I took it apart last night. There was no rebuilding of the left rear. The pad has spit out and the phonolic pistons were nearly completely spit out, and the bottom piston was broken. One of the slide pins is rusted and hung up. I think I am going to replace the mounting bracket due to the pin being siezed. I cant wait to see what the right side has in store for me tonight. BTW, my old 2500 chevy 4x4 FRONT brakes were not this Beefy!
Old Nov 9, 2010 | 06:57 AM
perryg114's Avatar
perryg114
What do you mean by spit out?
Perry
Old Nov 9, 2010 | 08:12 AM
EMC V10 X's Avatar
EMC V10 X
Perry
Because the slide pin siezed, the calipers did not slide as the pad wore, so the pistons hyper extended and one came out so far it cocked in its bore....
Old Nov 9, 2010 | 11:41 AM
perryg114's Avatar
perryg114
Sounds like pitting may not have been the source of the leak. I need to fix a stuck slide on my Excursion and I would like to do it before going to FL but I may not have time to deal with it. The pads are not worn completely out but they are not even from right to left.
Perry
Old Nov 9, 2010 | 12:02 PM
EMC V10 X's Avatar
EMC V10 X
Pitting definetly was not the source. the source of the leak was the piston coming out!
Old Nov 9, 2010 | 05:19 PM
aklim's Avatar
aklim
I know it is cheaper to do one side but I wouldn't. I can earn money back a lot easier than I can regenerate my body parts. I got some from ORiley and they were gold colored and you can tell that there is some sort of plating.
Old Nov 9, 2010 | 06:01 PM
EMC V10 X's Avatar
EMC V10 X
I have one held at the parts house. I will decide when I pull it. the Hawk pads should be in tomarrow or Friday.
Schlominator
Dec 6, 2016 10:33 PM
BlackTruckDave
Oct 19, 2016 12:23 PM
Da_Lariat_Chariot
May 12, 2016 10:01 AM
tgreen
Jan 7, 2013 04:39 PM
woody1003
Sep 5, 2004 10:40 AM
