Timing cover - harmonic balancer seal
Old Nov 7, 2010 | 12:23 PM
jemini's Avatar
jemini
1988 f250 351W
Can the round seal that the balancer goes through be replaced without removing the whole timing chain cover assembly?
Thanks
Old Nov 7, 2010 | 01:14 PM
Lazy K's Avatar
Lazy K
That is the front crankshaft seal or timing cover seal. Never did a 351 but I would be sure that the seal is installed from the inside of the cover so it would have to come off.
Old Nov 7, 2010 | 08:32 PM
jemini's Avatar
jemini
I was hoping it might be easier - thanks.
Old Nov 8, 2010 | 04:37 AM
EPNCSU2006's Avatar
EPNCSU2006
I'd say give it a try before pulling the timing cover. Best I can remember, the bore that the seal presses into is straight through the cover.
Old Nov 8, 2010 | 07:05 AM
jemini's Avatar
jemini
EPNCSU2006 - I definitely check it out first.
Old Nov 8, 2010 | 12:12 PM
68 351 bronc's Avatar
68 351 bronc
That seal has a steel lip on it. I don't remember if it goes in from the front or from the back. If you don't see a lip from the outside, the cover will have to be removed.
Old Nov 8, 2010 | 12:21 PM
86F150302's Avatar
86F150302
The lip is on the outside. I replaced mine when it was off while I redid the timing cover gasket.
I dont think you will be able to get the old one off while its still on the truck.
Old Nov 8, 2010 | 01:39 PM
jemini's Avatar
jemini
Thanks for all the info - I have the Felpro gasket set with all the required gaskets and the seal for the timing cover - and if removing the cover is the only way to go then that's what it'll be.
Old Nov 8, 2010 | 02:32 PM
Old93junk's Avatar
Old93junk
You can replace the seal while the cover is still mounted to the engine..........Will you be able to seat it straight and properly, and to the correct depth.......not so much.
Pull the cover and do it right, doing things twice sucks.
Old Nov 8, 2010 | 03:09 PM
lew52's Avatar
lew52
It can be done with the right skills & tools , but i think it would be best to remove the cover , then you can have a look at the timing chain , if theres any slack just replace it & the gears while your in there , have a good look at the water pump to....Lew
mawagian
Oct 18, 2015 04:41 PM
General Geoff
Dec 28, 2014 01:39 PM
copen93
Nov 25, 2014 09:08 PM
dgrant09
Apr 20, 2008 04:06 PM
79FordBlake
Dec 5, 2007 09:20 AM
