Ok, so it refers to total volume and not the 100% coolant volume. Thanks, and this is why FTE rocks! I think I'm going to create a "Complete Idiot's Guide to Owning a 7.3L PSD." I'm already collecting enough notes to make it pretty easy.
No need to do all that. 50% anti-freeze + 50% water = 100% coolant. Good luck with it
Here's what he said back in 2008:
"The Primeatech ELC is an excellent coolant for you...certainly better than the Zerex G-05. It is rated EC-1 which is the toughest spec in the industry. Long robust life and virtually maintenance-free. It is made by Houghton Chemical, a very reputable and premier chemical supply company. You done good."
It's available at FleetPride. They're almost everywhere, so it's easy to find. Also available as 50/50 pre-mix.
