Coolant and SCA
Old Nov 7, 2010 | 07:42 PM
Stewart_H's Avatar
Stewart_H
Originally Posted by jeronlines
... and hopefully in another 100k miles when I do another coolant flush.
You know a HD ELC will last longer than 100k miles, yes?
I use Chevron Delo ELC and it's good for 750k miles, or 1 million with an extender.
Most ELC's will be good for between 300k and 600k miles.
Also, I'd recommend you get a thermo housing from Dieselsite. It's billet aluminum and holds up better than the stamped steel OEM piece when multiple take-off and put-back-on's come into play.
Stewart
Old Nov 7, 2010 | 07:59 PM
jeronlines's Avatar
jeronlines
Yeah, I know from reading your most excellent posts- no sarcasm, seriously, this is truly enlightening and I love learning this stuff. That was more my cynical sense of humor sneaking through cuz I figure I'll miss something, it'll break, I'll lose fluid all over the road or parking spot and end up doing this again. Hence, an unintentional fluid flush.
Do I need thermo housing as well as the upper and lower parts? I'm looking for the Dieselsite now....
Old Nov 7, 2010 | 08:03 PM
Stewart_H's Avatar
Stewart_H
Here ya go: http://www.dieselsite.com/index.asp?...ROD&ProdID=188
Billet aluminum piece............................................. ....... stamped steel OEM piece
"Need" can be such a subjective term, LOL!
I really like the thermo housing. It's a huge improvement over stock, and allows you multiple reuses if necessary. The stamped steel OEM piece is easily goobered up.
One could argue that for the cost, it's just as easy to have a few OEM replacements in your garage, but I prefer upgrading to the improved version Bob sells.
Stewart
Old Nov 7, 2010 | 08:35 PM
jeronlines's Avatar
jeronlines
From Dieselsite, I am going to get the filter system, 203* t-stat and billet housing, so from the below list what do I need or are there duplicate parts-
It seems the t-stat assembly could go (getting 203* from Dieselsite), but the upper and lower t-stat housings are confusing. I've read my Haynes and Ford workshop manual, does the billet housing replace the need for both parts?
Cooling, Radiator and components, Overflow hose, Outlet, THERMOSTAT ASY- $26.56
Cooling, Radiator and components, Thermostat hsng, Upper, Upper- $20.21
Cooling, Radiator and components, Thermostat hsng, Lower, Lower- $44.64
Water pump & lower pump outlet? Should I replace? I've owned the truck five days and driven it 400 miles. I don't think I can even guess if the water pump might need to be replaced. But, for $150 I could save myself... hrs of pain?
Old Nov 7, 2010 | 09:00 PM
jirwin's Avatar
jirwin
get the upper radiater hose that goes around the belt. a few dollars more, but you can change belt without pulling the hose
Old Nov 7, 2010 | 09:52 PM
spdmpo's Avatar
spdmpo
I wouldn't do that 203 stat and billet housing personally. In fact I didn't do that. If you search around there were quite a few people unhappy with the billet housing and leaking. Using the 203 stat is arguable, make your own decision there but logical thinking suggests higher water temp = higher oil temp. Just get a factory replacement housing, stat, hoses, and anything else you might want from parts guy ed and have oem stuff. Tell him what you want and the part numbers magically appear in your shopping cart. It's unlikely you'll ever need to remove or reuse the housing anyway. I bought all that stuff and a new fan clutch and water pump from him and did it all in one shot with the ELC change.
Old Nov 8, 2010 | 05:18 AM
jeronlines's Avatar
jeronlines
So what is the conventional wisdom regarding coolant filtration? Worth the $100 or maybe not. The truck already has 160k miles, so wouldn't the coolant and tranny already have passed all the residual particulate matter?
Old Nov 8, 2010 | 07:04 AM
cj45lc's Avatar
cj45lc
IMHO I think Ford just cheaped out on the coolant filter. Look around at diesel engines period, you won't see them w/o filters. There is a pic on here of the drop-out of the SCA in the coolant, that's what eats up your water pump seals among other things.
Old Nov 8, 2010 | 03:19 PM
jeronlines's Avatar
jeronlines
When I do this whole deal, flush, replace hoses and t-stat, water pump, etc how long should I expect?
Old Nov 8, 2010 | 04:01 PM
cavitation's Avatar
cavitation
It took me around 5 hours total for 3 flush cycles and pump replacement. First flush with a garden hose through heater hose T, then 2 flushes with distilled water. Don't forget to remove the thermostat and finger tighten back on the old housing prior to flushing. The Gooch directions are great. I only pulled the driver side engine coolant drain plug during drain and flush cycles though. I am sure others have done it in less time but I prefer a methodical but slower pace.
Old Nov 8, 2010 | 04:27 PM
cj45lc's Avatar
cj45lc
That sounds about right, I farted around & took about that long with the flush & hoses.
Old Nov 8, 2010 | 05:47 PM
Stewart_H's Avatar
Stewart_H
The first time I did it, it took me a little over 6 hours, but I had problems getting all the green flushed out of my Excursion.
The second time I did it (my F250), it took me a little over 3 hours, but the Ford gold flushed much quicker and easier.
Stewart
Old Nov 12, 2010 | 11:11 AM
  #28
jeronlines's Avatar
jeronlines
Got the test strips, and as I suspected they came back with "recharge- 1 pt per 4 gallons." So, I think they guy never put any additives in the system. My plan is to put a pint in the degas bottle and let it mix (since the coolant "should" be 50% coolant and 50% water, approx 8 gallons total so 4 gallons of coolant = 1 pt of additive, right?).
Old Nov 12, 2010 | 11:32 AM
  #29
cj45lc's Avatar
cj45lc
Hey bud you got 8gals of coolant. I'd put 2pt of additive & check it again after you drive enough to let it mix good.
Old Nov 12, 2010 | 12:17 PM
  #30
jeronlines's Avatar
jeronlines
Ok, so it refers to total volume and not the 100% coolant volume. Thanks, and this is why FTE rocks! I think I'm going to create a "Complete Idiot's Guide to Owning a 7.3L PSD." I'm already collecting enough notes to make it pretty easy.
