Ignition key won't turn
I have a 1981 Ford Motorhome Econoline and the ignition switch lock won't turn. Anyone have any help that they can provide on what to do to fix the problem. Thanks.
I have a similar problem. This works for me. After inserting the key, back it out just a hair, and I do mean a hair.
Are the wheels cut over hard? Try shaking the wheel left and right while turning the key. Try some lubricant in the key way.
Originally Posted by WVVan
(Post 9531290)
Originally Posted by FordRv1981
(Post 9527662)
I have a 1981 Ford Motorhome Econoline and the ignition switch won't turn. Anyone have any help that they can provide on what to do to fix the problem. Thanks.
Ignition Lock Switch
Originally Posted by econoshorty
(Post 9534781)
Is in the column or the dash ? A new switch is a cheap and easy way to see if ithe switch is bad.
