Radio antenna replacement
Old Nov 6, 2010 | 04:24 PM
bmiller131's Avatar
bmiller131
Has anyone replaced their factory radio antenna with a shorter version? I'll need to do this if there's any chance of fitting in the garage.
Old Nov 6, 2010 | 04:31 PM
srkr's Avatar
srkr
Mine wouldn't fit in the garage either. So I took a hacksaw to it and pulled the ball off. I stuck the ball back on after the hacksaw job,...and touched up the scratches with black paint,,..works like a charm.
10 minute Fix.
Shane
Old Nov 6, 2010 | 04:56 PM
bmiller131's Avatar
bmiller131
Wow. I'm not sure I could bring myself to do that. Kinda like castration. I guess its an option though.
Old Nov 6, 2010 | 06:32 PM
BostonDMD06's Avatar
BostonDMD06
HAHA...no way man...it's my baby! That's like cutting off a finger!
Old Nov 7, 2010 | 06:01 AM
bdb2047's Avatar
bdb2047
I changed mine for same reason.Rubber boot on bottom will come out antenna mast just screws off.Can find short replacement at any auto parts store.
Old Nov 7, 2010 | 08:18 AM
bmiller131's Avatar
bmiller131
Great! Thanks.
Old Nov 7, 2010 | 08:28 AM
wiedsworld's Avatar
wiedsworld
I just drive in and out of the garage, it hits going in and out, but it's flexible and doesn't seem to hurt it. Also, it does no damage to my garage door.
Old Nov 7, 2010 | 01:25 PM
kper05's Avatar
kper05
Same here but I do have to fold the mirrors in. I take it easy and no damage to the door paint but it's visits to the garage are rare.
Old Nov 7, 2010 | 01:31 PM
srkr's Avatar
srkr
WUSSES!!! It's a truck!!!
Plus it looks and Works great. Every night it's in the garage.
Shane
Old Nov 7, 2010 | 04:53 PM
don.joyce59's Avatar
don.joyce59
My truck will not fit into my garage but my Explorer does. The antenna hits every time in and out. Doesn't seem to hurt anything.
Old Nov 8, 2010 | 09:33 AM
KeithLambert7's Avatar
KeithLambert7
Could use the stock antenna as a good height pre-warning system so as not to crush the cab run lights. I'll cut it so that it's about a half an inch higher then the lights. If the antenna scrapes, I'll back up.
Old Nov 8, 2010 | 09:37 AM
bmiller131's Avatar
bmiller131
Not a bad idea.
Old Nov 8, 2010 | 09:42 AM
djjoshuad's Avatar
djjoshuad
I don't have clearance lights (kinda wish I did) but my antenna hits every girder beam for 4-5 floors in the parking garage at work. I had replaced it with a shorter fiberglass one, but the carwash broke that one for me. For the last month it has had the stock one back on and smacking those beams twice daily. It's pretty torn up now.
The shorter fiberglass one came from Autozone and I think it was about $15-20. It worked well before it was broken
Old Jun 13, 2011 | 02:57 PM
blueovl150's Avatar
blueovl150
Simple solution!!
This one is so easy, it makes me laugh!
Simply measure the distance from the floor to the top of the radio antenna mast. Then measure the distance from the top of the radio antenna mast to the obstruction. Then lower the suspension of the truck in question accordingly! You will clear the overhead obstruction with no problems, and your truck will look just that much cooler! (This modification may require that you purchase a "coffee can" tailpipe extension that makes your pickup sound flatulent...).
Old Jun 13, 2011 | 04:01 PM
buckmasters's Avatar
buckmasters
Here is what I went with on mine. I had a tall one that hit in garages, then a short rigid one, but it kept getting bent in the carwash. This one is flimsy rubber, but works fine.
Amazon.com: Scosche RM906R Rubber Antenna Replacement Mast: Electronics
