Radio antenna replacement
  #31
Old 01-17-2019, 11:27 AM
tradosaurus's Avatar
tradosaurus
tradosaurus is offline
tradosaurus is starting off with a positive reputation.
F250 Antenna replacement F250 Antenna replacement
Perfect height to not scrape the carport and reception is still good.
  #32
Old 01-17-2019, 07:53 PM
maxum96
maxum96 is online now
maxum96 is starting off with a positive reputation.
That's the one I bought. Works good and looks OEM. Haven't noticed any issues with reception of FM stations.
  #33
Old 01-18-2019, 05:00 PM
clayguy
clayguy is offline
clayguy is starting off with a positive reputation.
I cut 4 inches off my stock antenna so it didn't hit garage door. No change in reception. I made a new small ball for the tip of the antenna with JB putty. Perfect.
  #34
Old 01-18-2019, 05:51 PM
lynnmor
lynnmor is offline
lynnmor has a good reputation on FTE.lynnmor has a good reputation on FTE.
The length should be 26 to 32 inches, with 29 being ideal. As you shorten the antenna, the best reception shifts towards the high end and as you approach 26 inches all stations below 108 will lose some degree of reception. I pulled into the garage till the antenna interfered and cut it as long as possible.
  #35
Old 01-21-2019, 02:00 PM
Liquid10Rider
Liquid10Rider is offline
Liquid10Rider is gaining momentum as a positive member of FTE.
It may have been mentioned already but on amazon they have an antenna call "the stubby" and its great! does not effect the signal and looks much better than the stock one. It is only about 3 inches tall.
  #36
Old 01-23-2019, 08:14 AM
Chuck-B's Avatar
Chuck-B
Chuck-B is offline
Chuck-B is gaining momentum as a positive member of FTE.Chuck-B is gaining momentum as a positive member of FTE.
Humm, I use mine as a "warning" for parking garages. If the antena hits I shy away from the garage. Sometimes works to my advantage, I tell parking attendants / venus I'm at that "my truck won't fit in the garage" and occasionally will be given premier parking for free.
  #37
Old 01-24-2019, 12:03 PM
NDE
NDE is offline
NDE is starting off with a positive reputation.
This is the one I bought. $25 with prime. 1 min to swap out and the reception is as good if not better than stock in my 2011 with a pioneer HD radio. It is sooooo much smaller than I thought it would be when ordered. it looks cool but will not have any issues with a car wash or parking garage.
goaroundflaps
1999 to 2016 Super Duty
11-18-2017 01:13 PM
goaroundflaps
11-15-2017 10:30 PM
banoness
Ford Truck Parts for Sale
09-21-2017 05:52 PM
Gary Lewis
2015+ F150
26
10-16-2016 03:56 PM
TexasGuy001
04-12-2016 10:13 PM
Quick Reply: Radio antenna replacement
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
