Sponsored by: Auxito
Overhead console compas/thermometer not working
Old Nov 5, 2010 | 07:24 AM
hojolabo's Avatar
hojolabo
Hi all !
Just bought an 03' F-150, FX-4 and the overhead console compass/thermometer is the only thing not working, was wondering if anyone can help me as to where to start looking for the fix or what should I expect.
The previous owner said he had a trailer light problem and it hasn't worked since. This has the factory tow package and wiring connections and the fuse panel checked out o'k.
Thanks for your help
Old Nov 5, 2010 | 04:16 PM
Bltfordtuff's Avatar
Bltfordtuff
I had the same issue, mine turned out to be the screen just went out. Got one from a junkyard for 100.
Old Nov 5, 2010 | 06:16 PM
jimm66's Avatar
jimm66
I had the same problem. Washed the board and hit all the solder joints. Worked again for a couple days then went out again. Got one at the yard for $15.00. Ford wants a lot for them. I think it was around $140.00. Good luck.
Old Nov 5, 2010 | 07:18 PM
hojolabo's Avatar
hojolabo
Can you tell me where the "board" is located to check it out?
Thanks, Howard
Old Nov 5, 2010 | 07:44 PM
jimm66's Avatar
jimm66
If I remember right, the screw is a phillips at the front of the console, toward the windshield.
Old Nov 5, 2010 | 09:49 PM
pantherscat's Avatar
pantherscat
Mine was going out intermittantly also. Its obviously an issue with them. When Im reallly reallllly bored one day I will pull mine apart and see whats up with it.
Old Nov 5, 2010 | 09:57 PM
jimm66's Avatar
jimm66
The boards develop a problem. I got the last one at the bone yard. The other locations didn't have any left.
djdrexler
Aug 1, 2012 02:00 AM
EZFEED
1997 - 2003 F150
Jan 25, 2010 06:18 AM
ANdrewdrice
Electrical Systems/Wiring
Feb 14, 2006 07:38 PM
