1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
What PSI should I run on 285/75/16 E rated tires on an F250 SD?
Old 11-04-2010, 11:17 PM
jlstorm's Avatar
jlstorm
jlstorm is offline
My mechanic always airs the tires up to the door specs, but I always run AT tires which seem to perform better at slightly lower PSI from what I hear. I just ordered good year duratracs 285/75/16 and I want to know what PSI I should tell my mechanic to go with. I rarely haul or tow and when I do its summer, not winter. I'll either be driving on highway or off-road. I would like the tires optimized for snow traction without sacrificing MPG if possible. Is there some sort of guideline since the tires usually have a pretty large range in recommended PSI values?
Any help would be appreciated.
Old 11-04-2010, 11:51 PM
Thunderduckie's Avatar
Thunderduckie
Thunderduckie is offline
I have the Bridgestone Dueler AT REVO's in this exact size on my '03. I run mine at 65 psi. Any less and the truck feels sluggish and is hard to steer, any more and it rides like a lumber cart. I have had my tires for almost 2 years and have 30,000 on them. This weekend I had the oil changed and alighment checked. They said I still have 50% left on the tread and good to go for this winter.
Old 11-04-2010, 11:53 PM
Thunderduckie
To be more specific: 2003 F-250 four door, 4x4, short bed, 5.4
Old 11-05-2010, 12:52 AM
Pocket's Avatar
Pocket
Pocket is offline
If you're loaded down or towing, it's usually better to air them up to the max.
If you're driving around empty most of the time, you can do the chalk test. Take some sidewalk chalk and draw a line across the tread of the tire. Drive the truck so the tires make a few revolutions. If the chalk wears out from the middle but not the edges, it's over-inflated. If the chalk wears out around the edges but not the middle, it's under-inflated. If the chalk wears evenly across the tread, it's just right.
For example, my tires are rated for a max of 55 psi according to the sidewall (load range D 325/60r20's). When empty I run 50 psi in the front, and 45 psi in the rear. That keeps my tires wearing evenly when driving around without a load. Your tires will vary.
Old 11-05-2010, 09:30 PM
Thunderduckie
Excellent idea Pocket. I had just adjusted mine for ride comfort and never considered tire wear. I'll be in the driveway tomorrow with the kids chaulk
anthonym92
08-22-2017 10:03 AM
kjephoto
1997 - 2003 F150
11-12-2015 09:58 AM
ztodd377
24
01-20-2013 07:53 PM
Blujay96
15
11-12-2010 09:47 AM
montgomery7
02-14-2010 07:19 AM
Quick Reply: What PSI should I run on 285/75/16 E rated tires on an F250 SD?
