Sct dashscan vs. Scanguage 2
Old Nov 7, 2010 | 08:22 PM
Unrealo4's Avatar
Unrealo4
Has anyone used a Sct dashscan? Its about $100.00 and I kinda like the way it looks over the scanguage 2. But it seems everyone uses the scanguage 2. it seems that they both do the same things nearly nothing different. Any reason not to get the dashscan over the scangauge 2?
Thanks in advance.
Link to sct dashscan .:ash Scan Automotive Data Monitor & Performance Calculator
Link to Scanguage 2 ScanGaugeII - Trip Computers + Digital Gauges + Scan Tool
Old Nov 7, 2010 | 08:29 PM
Misky6.0's Avatar
Misky6.0
The scangauge2 will read the Engine Oil Temp & Trans Fluid Temp,
but you have to manually add them using the xgauge menu.
Check with the DashScan folks include these "non standard"
sensors - or give you a method to manually "add" them.
It is also model year & model dependant as to which sensors are
on the ODBII (my '05 Ex doesn't have turbo boost) but it's possible
other model years (or F-series) DO.
Old Nov 7, 2010 | 08:38 PM
Unrealo4's Avatar
Unrealo4
Yeah it seems the dashscan monitors the ect and eot. And includes a way to add a egt temp sensor.
Old Nov 7, 2010 | 08:45 PM
High Binder's Avatar
High Binder
Originally Posted by Misky6.0
Trans Fluid Temp,
I can't get my TFT to work.
Old Nov 7, 2010 | 08:54 PM
Misky6.0's Avatar
Misky6.0
6.0L Diesel Transmission Temperature 07E1221674 046205160674 3010 000100080000 TFT Degrees F
This is the line from their Xgauge manual which worked for my '05 Excursion.
There are 2 other TFT sensors listed in the Xgauge manual, maybe you picked one of those
by mistake?
Could also be your vehicle is different (for example, I don't know about '03 Ex or '07 F-series)
Old Nov 7, 2010 | 09:59 PM
Unrealo4's Avatar
Unrealo4
Does anyone use a Sct dashscan? any quirks or reasons to buy the Scanguage 2 over the Sct dashscan?
Old Nov 7, 2010 | 10:30 PM
High Binder
by mistake?
Thank you (rep given) I'll give them a shot. I've tried a few of them already so hopefully this one will work.
good2eat
Dec 6, 2013 05:09 PM
ROBBINthaHOOD
Jul 20, 2012 01:26 AM
draboo
Nov 15, 2011 10:10 AM
hjsimpson
May 21, 2010 12:26 AM
myexpo02
21
Jan 26, 2009 07:58 PM
