1978 - 1996 Big Bronco
A4OD shifting issues.
Old Feb 16, 2014 | 06:51 PM
Ford Guy 72's Avatar
Ford Guy 72
Question A4OD shifting issues.
Hi, I just purchased a 1991 bronco with the 5.8L and automatic. I think it is the E4OD. I'm having hard shift issues. Not all the time. Also when I put it in drive or reverse it will slam in to gear and kill the engine. Today I checked the wiring at the trans and the relays then disconnected the battery for a minute. Now it shifts into drive or reverse smooth but when driving it will not shift out of first gear while in drive. Will work in first or second but not drive. If I let off the throttle and reapply the throttle while I'm moving it will act like its between gears or nuetral. Is this a shift solenoid that is bad?
Last edited by Ford Guy 72; Feb 17, 2014 at 10:55 PM. Reason: Had the wrong Starting letter for the trans.
Old Feb 17, 2014 | 09:52 AM
Kemicalburns's Avatar
Kemicalburns
you would have the E4OD tranny. I would do 2 things, first pull codes i would then drop the trans pan as i suspect the transmision filter had dropped into the pan.
the solenoid pack could be bad although i would check these other items first as they are cheaper.
Old Feb 17, 2014 | 10:53 PM
Ford Guy 72
Yes It is the E4OD. I will check that stuff tommarrow. I'll let you know what I find. Thanks.
KLONDON
32
Jan 27, 2024 05:46 PM
Nitesaber
33
Oct 1, 2017 02:43 PM
Mowing Man
Apr 5, 2014 05:59 AM
IDIDieselJohn
Feb 6, 2014 10:14 AM
MONAVIERONJON
Nov 7, 2009 03:08 PM
