Sponsored by: Real Truck
cold air intake
Old Nov 3, 2010 | 03:58 PM
bohiaa's Avatar
bohiaa
cold air intake
hey all:
was thinking about a cold air intake, wondering to know if anyone that has intalled on seen any improvement in fule milage?
not to concerned with preformance, and what brand is better ?
it's a 2000 Sd 4X4 v10
thanks
Old Nov 3, 2010 | 04:20 PM
brd7666's Avatar
brd7666
I put a K&N on mine. I got about one mile per gallon more after I put it on.
Old Nov 3, 2010 | 05:00 PM
SuperDutyScaler's Avatar
SuperDutyScaler
got a 04 with 5.4 and custom tuned SCT chip didnt see any gain in performance or mpg. i have since went back to stock intake with napa premium filter for two months no change in performance or mpg plus ten times better filteration with stock over k&n filters
Old Nov 3, 2010 | 06:23 PM
spinella's Avatar
spinella
i picked up a s& b set up from mike at 5 Star Tuning | Custom Dynomemeter Chassis Tuning Products and Services i dont know about HP claims but i do like to be able to service my filter.
Old Nov 3, 2010 | 07:01 PM
acf6's Avatar
acf6
i would just go with a high quality filter. i found out the aftermarket CAI's are useless
Old Nov 3, 2010 | 07:03 PM
mwsF250's Avatar
mwsF250
Look under the hood. The stock system is CAI.
If you want to see an mpg improvement, make sure the old filter is absolutely filthy before changing. Otherwise, you'll be disappointed. The stock filter setup in the V10 is very, very good. Unless you're doing a bunch of other stuff to pump up power, (cams, headers, exhaust, porting, etc etc etc), it's not worth the cost.
Some of us have replaced the small snorkel inlet with the much bigger one from an '05 plus air filter housing (has to be glued on after enlarging opening on stock housing) and feel a small improvement at high power levels. Helps for hard pulls (towing up grades) at 4K+ rpm.
Old Nov 3, 2010 | 09:33 PM
Roasted7's Avatar
Roasted7
I've got the aFe Power Pro Dry S magnum force cold air intake. The filter works just fine and I have no idea about MPG or power gain as I change some other stuff at the same time. I've had no problems.
Old Nov 3, 2010 | 10:31 PM
onug's Avatar
onug
I've tried aftermarket filters on a number of vehicles. On my F150, I did a dyno test before and after. I actually lost power with the aftermarket filter. I forget what the "term" is, but the computer's job is to maintain the right air to fuel ratio. More air in, just means the computer feeds more fuel. You won't see an increase in mpg.
Old Nov 4, 2010 | 05:43 AM
cliles55's Avatar
cliles55
I've noticed more noise pollution since installing the K&N but I like a little growl under the hood.
Old Nov 4, 2010 | 10:36 AM
ChargersFanInCO's Avatar
ChargersFanInCO
They're useless...BTDT, then read the forums.
Old Nov 4, 2010 | 03:34 PM
bohiaa's Avatar
bohiaa
Ok thx guys. I recently did a tune up and I had a Vacume leak. replaced the IAC. it looks like I gained about 1 to 2 MPG.
I know that some engines do well with larger air flow, that's why I was thinking about cold air intake. and some do NOT.
thanks again for saving me 2 to 3 hundred dollars
clyde705
2004 - 2008 F150
Nov 26, 2012 04:56 AM
MountainHawk
2004 - 2008 F150
Dec 31, 2011 01:49 PM
mudlite
2004 - 2008 F150
24
Sep 20, 2008 07:19 PM
uncleglenny
1997 - 2003 F150
Apr 30, 2006 09:06 PM
