Help Please!
Old Nov 3, 2010 | 03:27 PM
GBURKS's Avatar
GBURKS
Help Please!
Truck died a few days ago, just talked to the mechanic and he says the following codes are showing
P0263 Cylinder 1 Contribution/Balance Fault
P0603 Internal Control Module KAM Error
I understand the first one to be the #1 injector, any ideas as to what is causing the p0603 code?
Old Nov 3, 2010 | 06:56 PM
cheezit's Avatar
cheezit
dont worry about the p0603. its a kam code. you will get that from low voltage, jump starting and things like that.
Old Nov 23, 2010 | 08:51 PM
caere's Avatar
caere
Good to know about KAM code thx cheezit! What about the other code?
P0263 Cylinder #1 Contribution/Balance
I have that one too
Old Nov 23, 2010 | 10:11 PM
jboczar's Avatar
jboczar
P0263 means you had a misfire on cylinder number #1 which will probably require a new injector. Neither one should have made your truck stall, I would check icp while cranking engine.
Also make sure P0603 does not come back after you clear it or you could have a pcm problem.
Old Nov 23, 2010 | 10:14 PM
cheezit's Avatar
cheezit
p0263 can make it stall but in a very round about manner. soem basic diag would be need to figure out if oyu have an injector fault
awillo0406
20
May 7, 2013 02:58 PM
Bazza51
May 18, 2011 02:47 AM
linemanford6.0
Oct 7, 2007 09:43 PM
bhs2869
Feb 4, 2004 01:00 PM
