New Aerostar!!
I had to buy a single 215/75R14 tire yesterday.
Most of the local places don't stock the size and very few places can even order them.
I found a hole-in-the-wall service center that had two of them in stock.
I kidded the owner (I actually went to high school with him) that the tires were old enough to vote. He checked the serial number and it was made in '07.
That's new enough for me and I'll probably buy the single tire that he still has in inventory.
#1. There is no other van that offers as much available cargo room while simultaneously offering legroom and overall passenger room.
#2. The only other van with truly comparable towing and hauling capabilities is the Astro, which is shorter, less reliable, and less safe.
#3. Grand Caravans are booth smaller, but also less heavy duty. A 120,000 mile Caravan is generally considered old, many of them act old. They are approaching the end of their life, few will make it past 150,000.
#4. The Odyssey is too expensive. It is reliable.
#5. The Flex is great for passenger space and towing, but its cargo room is limited.
#6. Many of the Aerostars shortcomings can be corrected. Example, the trans can be upgraded to make it more reliable. The rear suspension can be lifted and stiffened to reduce body roll.
#7. They are easier to work on than most other Minivans. Anyone here changed plugs on a Windstar? How about a starter?
#8. In terms of long term reliability, they seem to rank supreme, smashing every other make. It is not uncommon to find Aerostars with over 200,000 miles. There are even some that have exceeded 500,000 miles.
#9. The only good alternatives for Aerostars are much bigger heavier gas guzzlers that cost more in the first place and cost more to maintain. The Aerostar seem to offer an ideal compromise between size, cost, maintenance costs, manueverability, and fuel economy.
Ok, so those are 9 good reasons why many of us drive and buy Aerostars. Could a Suburban or half ton van do the job? Yes, but they would be bigger, heavier, and they cost more to maintain. I'm not just talking about engine repairs, I'm talking about the routine stuff too, like brakes, tires, wheel bearings, etc. Bigger vehicles tend to have more expensive parts.
The employee was behind her back laughing when I thanked the lady for her expertise and told her to have a good day. She was still glaring at me when I drove away.
I'm on my fourth Aerostar. It will probably turn 200K miles this week. My previous three all lasted over 250K before I purchased another one.
One point I'd question -- #2. The Astro is less safe than our Aero? I'd like to know your thoughts as to why, Khan...I would think they'd be fairly equal. Airbags, although I can see where the footwell intrudes into the driver's cabin - is that what you're meaning?
Load stories...
- I helped my brother get his all-metal lawn furniture into my van...2 lounges, a big table with all 6 chairs in 1 trip and the thing wasn't even near the bump stops.
- I loaded all the lumber I needed to build the footings (not the rails) of my deck, an L - shaped one which is like an 8x8 box and a 8x4 box. I was at the bump stops then...
- Towed a utility trailer that we calculated later to have about 4000lbs of gravel inside...didn't even break a sweat even at 300,000kms.
As for 14" tires, my Firestone rep has plenty - Firehawk Indy 500's come in "our" size (I just checked - mine are 225/70R14's). I have 4 on there now and it corners as well as can be expected for a vehicle that weighs as much as it does.
Good luck on your "new" Aerostar!
The reason the S-10 chassis rolls is when you corner, especially hard corners, the chassis twists like a spring, which combines with the mushy suspension, which does the same thing. When the spring is unwound, it releases with enough energy to tip the vehicle pasts its COG, and a rollover is the result.
One example is a story of tires, the point of the story is about old tires being sold as new. But the example story involved a college student who was driving with a friend to some event or reunion or something don't remember. Anyway, one of the tires blew out, and the vehicle rolled. I've had a bad blowout on my vans, guess what, it wasn't even exiting, it was just annoying, especially as I had taken the jack out to work on another vehicle had had neglected to put it back in the van. I ended up with the highway patrol stopping by. They had a big floor jack which made short work of it.
Some of the early years of the Aerostar had a higher incindence of rollover accidents, but it took a combination of things going wrong, namely, the vehicles were overloaded, the vehicle suffered a tire blowout or collision, and the driver overcorrected.
Sorry not meaning to preach to the choir about Aerostars, but someone, not a member may look at these reasons for choosing one, and then join and contribute to our Aerostar family.
I'm in the process of partially repainting and restoring mine. I'll tell you what, paint work is time consuming. Its mostly the well known rocker panel rot. Mostly because some bozo smashed the rocker panels in with a 2 post lift. Anyway, I've got most of the prep work done, just a few more spots to fix, then the paint can go on.
I plan on painting the rocker panels themselves with Reflex liner, dark grey color. I plan on doing the same on the bumpers.
The way to fix them is to pull them out, which needs to be done at a body shop. They can attach various fittings and stuff to the area and then pull it.
Basically from the beltline up it looked squashed sideways and down, but he was able to put it back on its wheels and drive it out. Insane!
Astros ride like lumber wagons compared to the Aero and the driver seat is a hemorrhoid machine.
the 4.3L V6 is a torque monster but sucks gas.
thought about trading in the Aero on a last production year Astro, glad I did NOT. the old girl just sets out there waiting for me, she starts everytime and runs like a Queen
My Aero has barely any rust even though it was stored outside and forgotten for nearly five years.
