Fuel Pump Eccentric Won't Spin???
Old Nov 2, 2010 | 06:02 PM
mabigredtruck's Avatar
mabigredtruck
installing a new cam and timing set (comp warranty...) and using the stock 2 piece eccentric. if i assemble everything the way the manual shows, the outer ring of the eccentric may as well be welded to the cam sprocket. i'm using a comp magnum true roller timing set which at least looks very similar to the ford design pictured in my ford manual. is it crucial for this thing to spin? should i find a sort of spacer to allow it to do so? or should i just bolt it down and turn it into a one piece? i've searched and searched and couldn't come up with good info, any help is appreciated.
tater_51
Feb 22, 2023 11:59 AM
4wheelex
Dec 17, 2010 10:45 PM
bourbon
Engine Swaps
Mar 28, 2008 03:33 AM
1pump
Sep 29, 2004 06:34 AM
BodieBell
Jun 13, 2003 05:31 PM
