1966 F100 VIN and door tag question
I recently purchased a 1966 F100. I was going through the door tag and I had a couple questions.
VIN#- F10YR886406
So it's an F100, 352 engine, built in San Jose in July 1966.
Now this is where the questions arise.
Door tag-- 129 W F100 281 A 08
05000 172 4000 74
I get the wheelbase, model and the bottom line but what doesn't add up is the 281 body style and the transmission. I couldn't find a 281 body code. And According to the decoder I found the A is only for 1965 but for '65 there is no Y engine code.
Anyone able to shed some light on this?
VIN#- F10YR886406
05000 172 4000 74
VIN#- F10YR886406
So it's an F100 2WD, 352 2V engine, built in San Jose in July 1966.
Warranty Plate: WB: 129 / COLOR: W / MODEL: F100 / BODY: 281 / TRANS: A / AXLE: 08 / MAX GVW LBS: 05000 / CERT NET HP: 172 / RPM: 4000 / DSO: 74
I get the wheelbase, model and the bottom line but what doesn't add up is the 281 body code and the transmission. I couldn't find a 281 body code.
And according to the decoder, I found the A is only for 1965 (3 speed manual, C = 1966 3 speed manual) but for '65 there is no Y engine code. D was used in 1965 for the 352.
VIN#- F10YR886406
129" Wheelbase.
W = Marlin Blue.
F100 2WD, 5,000 lbs. GVWR
281: 2 = Medium Blue Crush Vinyl & Medium Blue Wicker Pattern Vinyl / 81 = 81A Standard Cab.
A = New Process 435 4 Speed Manual Transmission (1965: N).
08 = Ford 9" Rear Axle / 3.50-1 / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
172 net HP @ 4,000 RPM
74 = Seattle WA Ford District Sales Office, where the original selling dealer ordered the truck from.
amaidemon
08-17-2012 11:49 PM
