Burning oil
Old Nov 2, 2010 | 07:24 AM
mstiles19's Avatar
mstiles19
Burning oil
My 5.4L is losing oil somehow. By every 3000 miles I will usually have to have added around 1.5-2 quarts of oil to keep it full. I have looked for spilled oil and never see any. I also have looked for smoke and have never seen any of that either. Any ideas?
I have 181000 miles on it and have been very religious about changing the oil every 3000 miles. I am thinking about adding the lucas oil treatment stuff to it cause it really helped out one of our older tractors
Old Nov 2, 2010 | 08:31 AM
Katmandu's Avatar
Katmandu
Question
I would absolutely add Lucas to your oil.
Your answer lies in the result of a Compression test (Wet and Dry).
Post up your #s when your done.
Old Nov 2, 2010 | 10:48 AM
mstiles19's Avatar
mstiles19
ok, I dont really know when i will be able to do it i believe that would be pretty time consuming on this motor
Old Nov 5, 2010 | 05:19 PM
phil6608's Avatar
phil6608
What about Additives?
Old Nov 6, 2010 | 05:46 PM
mstiles19's Avatar
mstiles19
Originally Posted by phil6608
well I already added it to my oil before I read your post so i decided to do a little testing myself. First i checked my oil and it was at the full marker, so i started my truck and checked it again and it was below the fill line and was not foamy or anything. It looked like good clean oil. Then I held my truck at 3000 rpms for 3 minutes and checked it again(with the motor still at 3000 rpm). The oil level was still the same and there were no bubbles in the oil nor was it foamy or anything.
The only thing that I have noticed since adding the oil additive was the slight knocking that my motor made has gone away. It is too soon to see if my oil consumption has been reduced but I should be able to notice soon.
I do know that the lucas in one of our old gas massey harris and diesel deere stopped them from smoking.
Old Nov 6, 2010 | 07:39 PM
galaxie641's Avatar
galaxie641
Sounds about normal to me, mine has been eating around that much oil for well over 100K miles. No smoke and only a very small leak at the oil cooler lines. I would simply add a qt. at around 1500 miles then change the oil around 3K-4K when it was a qt low again.
Old Nov 6, 2010 | 07:58 PM
mstiles19's Avatar
mstiles19
galaxie thanks so much. this makes me feel better that its not just mine. I have looked for leaks i will check the lines much better.
Old Nov 6, 2010 | 09:22 PM
phil6608's Avatar
phil6608
I think ford says it's within spec for it to use 1 quart in 3000 miles. So 1.5 to 2 quarts is not bad at all for your 180000 mile motor.
As for the lucas thing. Just thought it was an interesting read.
Old Nov 6, 2010 | 09:27 PM
galaxie641's Avatar
galaxie641
I was told 1qt every 900 miles. Took mine in way back when I was still under warranty
and it was starting to eat some but not that much.
Old Nov 7, 2010 | 07:12 AM
acf6's Avatar
acf6
if its common for his 180k mile motor to use 1.5-2 quarts, ive put 2 full quarts in and im about 1/4" down from MAX with 4600 miles and 40k on the truck
Old Dec 6, 2010 | 06:28 PM
kipdog's Avatar
kipdog
my 01 has 135K and it uses about a quart every 3000 mikes with no leaks, need to add some lucas. Just changed oil in my other beast 99 f250 v10 6.8 and added some lucas.
rsylvstr
Modular V8 (4.6L, 5.4L)
Nov 15, 2015 10:07 AM
MP1F-150
2004 - 2008 F150
Feb 24, 2013 03:51 PM
CopenGrizz01
Jun 10, 2012 10:46 PM
carrnut
Dec 13, 2008 06:49 PM
classicranger
Oil & Lubrication
Sep 21, 2007 04:30 PM
