Sponsored by: Real Truck
carrier/support bearing replace
Old Nov 2, 2010 | 06:14 AM
workforBeaver's Avatar
workforBeaver
I have an 07 F-350 (srw) that I think the carrier bearing is shot on. How big of a job is it to replace this bearing? Looks pretty straight forward except I'm not sure about how to remove and reinstall the bearing it self. Do you have to have it pressed on?
Old Nov 2, 2010 | 06:55 AM
bubbasz1's Avatar
bubbasz1
If it is like my 2001 yes it is pressed on. Before you pull your shafts mark the U joints for position so they go back exactly as removed, otherwise you could get a vibration worse than what you might have now.
Old Nov 2, 2010 | 08:17 AM
DAVE67FD's Avatar
DAVE67FD
What indications are you experiencing? What mileage do you have?
I believe mine is also on the way out at 90k, no vibration just bearing noise.
Old Nov 2, 2010 | 02:28 PM
workforBeaver
I bought the truck used, it now has 174000. miles on it. there is a grinding noise from the rear of the truck so I thought rear wheel bearings, I replaced them. During that little job I found so much mud packed under the truck I power washed for 45 minutes. found the park brake backing plate completely rusted out and the shoes were rubbing the inside of the drum. The noise is still there so I figure go to the next bearing and try it. After work this evening I will crawl under and see how much play there is to try and confirm it really is that bearing.
Old Nov 2, 2010 | 11:00 PM
kc7gjs's Avatar
kc7gjs
Just had the carrier bearing replaced on my 2001 F-250. I considered doing it myself. I thought the following thread was good resource: https://www.ford-trucks.com/forums/9...nt-w-pics.html. I ended up taking it too a shop but would consider doing it myself next time.
Old Nov 3, 2010 | 05:29 AM
workforBeaver
thanks Kc7gjs that link is great. This is exactally what I need to help fix my problem.
rockittsled
May 17, 2014 08:08 PM
powerstroker100
Nov 1, 2011 08:04 PM
slothshady
15
Jun 9, 2004 10:41 AM
firedad
Aug 16, 2003 01:12 AM
