Sponsored by: Real Truck
99 v10 REBUILT>>>>>MISS>>>>>>NO CODE
Old Nov 1, 2010 | 07:46 PM
mike bell's Avatar
mike bell
after a valve grind, heads magna fluxed, and decked..... the cylinder walls...still had the cross hatches, this baby ran perfect for three weeks then it would miss for a minute then be fine.....misses all the time now.....dealer says this is how coil overs act on the way out... spordiac like that.....the problem is this is apperently not bad enough to throw out a code....so short of taken out to the big scope.....200$$$ is there a way to figure out what ## ??? Mike in Omaha
NEW PLUGS AND BOOTS OF COURSE
Old Nov 1, 2010 | 09:32 PM
redford's Avatar
redford
FTE Leadership Emeritus
Have you scanned for PENDING codes?
Old Nov 1, 2010 | 10:14 PM
mike bell's Avatar
mike bell
the guys at advance auto say it has to say: check enjine light: to see if aything is wrong...tell me more thxs mike in Omaha
Old Nov 2, 2010 | 06:21 AM
BenFranklin's Avatar
BenFranklin
I know a thing or two about these coils....
I wrote a sticky about them on a mustang forum I am a member of.
Just buy these and throw em in.
Here is the link to the write up....
Old Nov 2, 2010 | 06:51 AM
bubbasz1's Avatar
bubbasz1
If someone you know has a good scanner it will tell you miss fires per cylinder, that is what you need to know, either switch out the COP or change them to another location to see if they missfire in that location to make sure it is the COP.
Old Nov 2, 2010 | 06:55 AM
BenFranklin
Missfires due to the COP are very commonly not reported. If he doesn't have a CEL, he's got nothing to go on in the missfire department. The thread I provided a link for goes over all the troubleshooting for this.
Old Nov 2, 2010 | 07:37 AM
bubbasz1's Avatar
bubbasz1
I have autoenginuity scanner software for my laptop, I had the same problem, no CEL, my software will tell you percent missfire per cylinder, that's how I fixed my missfire issue. All depends on the scanner being used, an autozone scanner will not tell you this, a snap on scanner or many others I'm sure as mine does, will tell you missfires per cylinder.
Old Nov 2, 2010 | 11:52 PM
mike bell's Avatar
mike bell
bought em cheaper than the dealership scope.....might as well;;thanks
Old Nov 3, 2010 | 01:55 PM
BenFranklin
That sounds great, but I wonder what it references to know that it has a misfire? I have a decent scanner, it does all vehicles, abs codes, data loggin, etc, but it still can't detect a missfire unless the engines computer detects it...and if the engine's computer detects it, usually it will throw a CEL. Not always, but usually. Hmmm. How pricey was that software you have?
Old Nov 3, 2010 | 02:43 PM
redford's Avatar
redford
No, actually you have to have an almost dead cylinder before you light a CEL on these engines. A misfire will throw a pending code, but before a CEL is lit you need X misfire codes over a Y time period. You can have a real rough running engine with no CEL. This is why it is important to use a scanner that reads the pending codes.
Old Nov 4, 2010 | 03:20 AM
PartsPaul62's Avatar
PartsPaul62
Banned
V-10 misfires...
I have read on this blog and in Ford service manuals that the CEL will not illuminate in many situations that you would otherwise expect. The reason is the V-10 is listed as a 'heavy duty engine' according to the emission folks.
The hand-held scanners that most of you (and me) have will not detect this. A high-end scanner (like the dealer has) with an oscilliscope will do the trick.
Mine was diagnosed in the service drive. Upon inspection the locking tab had broken out of the plug causing an intermittent connection.
Old Nov 4, 2010 | 11:07 AM
BenFranklin
Gotcha, that makes perfect sense now. But still...my scanner reads pending codes...wonder why I never was able to see any misfires before.
Old Nov 4, 2010 | 12:31 PM
bubbasz1's Avatar
bubbasz1
Around 350.00 for the Ford module.
mike68gt
2004 - 2008 F150
Oct 2, 2014 08:43 PM
MIKES 68 F100
36
Mar 25, 2014 08:13 PM
Supercab
24
Jun 16, 2009 10:14 AM
pntrbil
Dec 28, 2001 08:24 AM
