Windshield wiper problems
Old Nov 1, 2010 | 04:43 PM
Fordfr4x4's Avatar
Fordfr4x4
Hey all got a 93 F 150 and the wipers are moving slow at all ranges only interment changes when I turn them up but same speed and there a is a loud motor noise with it. Just replaced the motor and the problem is still here. Is it the switch behind the glove compartment? I looked at it I see 2 a big one right by the vents in front and a small kinda hidden next to that one a touch smaller anyone know which one it is? thanks guys.
Old Nov 2, 2010 | 04:01 AM
TexasGuy001's Avatar
TexasGuy001
When you say they move slow, do you mean like normal low speed or slower than that?
The larger flat one behind the glove box is the RABS module.
Old Nov 2, 2010 | 09:50 AM
Fordfr4x4's Avatar
Fordfr4x4
Yeah the intervals are where they should be like on the highest it still moves where it should just slowly and makes like a groaning noise. I think I am going to go to the junk yard and get a new interval switch. If thats not the bigger one then it must be the smaller one behind the glove compartment kinda stashed into the dash a little bit.
Old Nov 3, 2010 | 04:14 AM
TexasGuy001
Before you go to the junk yard, you could price a new one. It might not cost as much as you think. Post back after you try that.
Old Nov 3, 2010 | 06:51 AM
SKS45's Avatar
SKS45
clean the contacts in the switch first. I spent hours taking the wiper control module apart and testing all of the circuits and diodes. I had no power at the motor. Thought for sure it was the module but decided to clean the switch, more out of frustration than anything. Guess what, after cleaning I now had power at the motor. Motor was frozen so I had to get a new one. However, the rebuilt motor is much cheaper than a replacement module. Give it a try, you might end up lucky like me.
Brett
Old Nov 4, 2010 | 03:52 PM
Fordfr4x4's Avatar
Fordfr4x4
You wouldnt be able to tell me where that is would you according to the chiltons its behind the insturment cluster but I cant seem to find it also I have no clue what I am looking for. Haynes says its behind the glove box.
Old Nov 4, 2010 | 06:27 PM
tjc transport's Avatar
tjc transport
i ain't rite
haynes and chiltons manuals are as useless as ***** on a bull.
Old Nov 4, 2010 | 08:09 PM
SKS45's Avatar
SKS45
Open your glove box. Squeeze the sides so you can open it further and let the door hang. Straight on you should see the ABS module. Look to the right kind of tucked up in the corner. That box about the size of a pack of smokes is the wiper control module. However, clean the switch on the stalk first. That could be the problem.
Brett
Old Nov 4, 2010 | 08:10 PM
SKS45's Avatar
SKS45
oops sorry, I see you have a 93. The location I described was for a 94. Not sure if it's the same or not.
Brett
Old Nov 8, 2010 | 03:30 AM
Fordfr4x4's Avatar
Fordfr4x4
I think it is I did that originally and saw it then didnt do anything cuz I read the haynes and it said it was behind the insturment cluster. But I think this is the box, thank you.
tm01027
Sep 11, 2017 02:57 PM
midsouth
Nov 26, 2015 07:08 PM
southtexasidi
17
Dec 16, 2014 09:28 AM
LaRell
Jun 8, 2013 10:57 AM
mblayton
1978 - 1996 Big Bronco
Aug 15, 2006 05:26 PM
