88 f250 with starting problems
Old Nov 1, 2010 | 12:18 AM
broncoman1532's Avatar
broncoman1532
its a 88 f250 4x4 with a 351 auto, i drive the truck to the store and back home try to start it and it cranks like the battery is dead (very slow). it does start if it sits for a couple of hours. battery is good new and the alt is good. could the starter or the solinoid be going bad. or maybe the ground going from the battery to the block. love the truck and just after i fixed the exh. manifold and a good tune up
Old Nov 1, 2010 | 12:36 AM
polarismuddman's Avatar
polarismuddman
Check all your grounds.....sounds like the starter may be getting heat-soaked which would cause that......
Old Nov 1, 2010 | 01:35 AM
broncoman1532
i think its the post terminal cause i looked at it today and it looked like it was melting *** i mount my cold air intake down behind the bumber ***
Old Nov 2, 2010 | 06:01 PM
broncoman1532
fixed the problem replace the neg. cable from the battery to the block
cadetspider06
Oct 8, 2011 02:25 PM
Ryan'sF250
Jul 6, 2011 01:05 AM
a ayala
May 6, 2010 09:29 PM
GUERILLA
15
May 27, 2009 06:17 AM
88f150302
20
Mar 23, 2009 09:25 PM
