adjusting doors
Old Nov 2, 2010 | 08:36 AM
bypassbill's Avatar
bypassbill
adjusting doors
I have replaced all the door hinge pins on my 96 F-150 and although the doors close better than they did the drivers side door is still hit or miss. Ot closes just fine if the window is partially down and I use the side pocket on the door for a handle! Is there any way to adjust the hinge itself?
Old Nov 2, 2010 | 06:07 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes. Where the hinges bolt to the cab, they are adjustable and where they bolt to the door they are adjustable. Just loosen them a lil bit and yo will have to force the door to make the adjustments. You DO NOT want the bolts loose. the door will flop around and it will take you hours
maxride
Mar 21, 2015 08:12 PM
alchemist1
May 6, 2014 02:30 PM
hardknox00001
Paint & Bodywork
Mar 30, 2014 07:32 AM
j7angus
Mar 12, 2012 02:25 PM
mr_ranger-79
May 22, 2011 06:34 PM
