2009 Edge SEL, front wheel drive, V6, 70000+ mls. I am 6'2" tall and 265#s and the vehicle is still plenty comfortable. Not as compfortable as my '08' Lariat, but still a blast to drive. Love the vehicle and no issues whatsoever.......until recently. The car has developed a growl, in the rear it sounds like. Almost like I am running mudders instead of Michelins. Thought it might be the tires so replaced all 4 with new of same type. Still there. The noise frequency increases as speed increases. Not just when rpm increase....but as the wheels are turning faster the noise gets louder and "faster". Doesn't really have that harsh metal on metal "feel" to it. Sounds like you are holding a screwdriver aganst the treads as the tire rotates. I drive freeways as I travel and this growl is not pleasent after 7 hrs or more driving. Not quite sure what to think. Any ideas
08 fwd.electric fans conked out.62000 miles last week.love it otherwise except 20.09 mileage last trip.all highway no cruise taking it easy.i wonder ic this thing is like the 05, 500 the faster you drive the better the mileage...yea did better @ 80-85 than 60....
07 Edge sel fwd with 58k and no problems. Brake pedal seems to have more slack(goes down farther) than my 99 Explorer. I drive 99 mostly and wife drives Edge and she doesn't complain about it. Probably need to get it checked out.
Had to have the left front wheel bearing replaced at 79k as it was making a noise at hwy speed especially on curves to the right. It would almost go away on LH sweeping curves.
Sometimes when unlocking the doors remotely the drivers door will re-lock. The button inside drops back down. The car has been trouble free mostly.
My brother has an '07 with 100,000. Other than a transmission at 70,000, no problems. And eve with that, Ford treated them right. Happened just outside of Amarillo on their way back home to Socal. Good folks at Ford in Texas.
2007 AWD
27000
Replaced a rear hub assy (around $130)
I'll do brakes after the winter
Oh, and the pass window is really slow... gotta deal with that too
Nearing 44k.
Replaced Both rear hub assemblies, including rear control arms, per TSB (all covered under power train warranty.)
Had a PS cooler hose let go, easy fix.
All else is well.
My wife and I own a basic 2007 FWD Edge w/o leather, navigation, and glass roof. We originally leased the vehicle, and we were so impressed by it's handling, functunality, etc. that we refused to give it up. Currently, the odometer is just below 71,000 miles, and besides having some A/C and heater core issues that were covered under warranty, the vehicle has been pretty flawless. We did experience issues with burned-out taillight bulbs, and luckily not as bad as others who had the wiring damaged. The symptoms we have experienced include having to replace the bulbs about once a year, so literally we have already replaced both the left and right about 3 times. Definitely, a good purchase.
