Sponsored by: Real Truck
Info about Powerstrokes!
Old Oct 31, 2010 | 03:41 PM
firefighter317's Avatar
firefighter317
Exclamation Info about Powerstrokes!
I'm going to work at a local Ford dealership and I will be the diesel tech there. I have been working on diesels for years but do not have much experience with the Powerstrokes, and thats why I took this job to learn more. I've been working for GM recently and seen my share of Duramax and have worked on Cummins on the side. I'm just curious as to what are some of the major/common problems you see with Powerstroke diesels? I guess I'll see over time, but I just wanted to get a heads up on things. All I know is that the variable geometry turbos on the 6.0s have a bad rep from what I've heard. Any info and heads up would be GREATLY appreciated! Thanks in advance!
Old Oct 31, 2010 | 03:47 PM
jstnromero's Avatar
jstnromero
I would just start reading thru all the different threads. There is so much out there to learn. You will obviously need to become familiar with the 7.3, the 6.0, the 6.4, and the new 6.7. I would take a look at all the various sections of the forum and just start digging around.
Good luck with your new endeavor.
Old Oct 31, 2010 | 04:08 PM
wulfman's Avatar
wulfman
Are you going to be the only diesel tech there
Old Oct 31, 2010 | 04:37 PM
firefighter317
no there is one other guy thats been there about 15 years but they are getting overwhelmed with diesel work because they have a lot of fleet work so they needed another one.
Old Oct 31, 2010 | 04:38 PM
firefighter317
Hes gonna help me get the hang of powerstrokes but I just wanted to gain as much knowledge on them as possible.
Old Oct 31, 2010 | 06:52 PM
husker's Avatar
husker
Like jstnromero said, go to the separate diesel engine forums here and they will send you to graduate school. Each forum covers one of the engines or main year grouping. Look through some of the major issues they cover and you will have a great overview of the things that present a problem on each engine.
Old Oct 31, 2010 | 07:02 PM
senix's Avatar
senix
6.4 forum right here:
6.4L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Biggest common item is radiator failures, they leak at the seams where they joined the plastic to the fins.
regens and black pipes, excessive regens and fuel related problems can be a common occurance.
Old Oct 31, 2010 | 07:54 PM
F350-6's Avatar
F350-6
Welcome to FTE. Glad to have you here. EGR issues are popular on the 03 and newer trucks. Head bolts that stretch and blow head gaskets on the 6.0, the radiator issues on the 6.4, I doubt you see many 7.3's at the dealer, but loose UVCH connectors and the recall CPS causing contribution fault codes on #3 & #8 injectors.
As mentioned, there's more engine specific info down in the diesel engine subcategories you can read up on, or hopefully start adding new threads and comments on.
Old Oct 31, 2010 | 08:32 PM
firefighter317
Thanks everyone for your posts! I really appreciate your help!
20017.3powerstroke
Sep 9, 2014 07:32 PM
granny_rocket
Nov 11, 2011 11:19 AM
matts156
Jul 1, 2009 10:29 AM
young_ford_fella
Oct 18, 2004 12:31 AM
GunNut
May 28, 2004 09:55 PM
