HELP: Where do I start checking?
Old Oct 31, 2010 | 04:54 AM
meck1's Avatar
meck1
I've got an 87 F250. The 300 engine is the fuel injected version. It has come up with a problem that I'm hoping someone can give me an idea where to start looking for the solution. It runs great at idle and at speed. But when the engine is warmed up and I'm idling then give it the gas, it will instantly hesitate, sputter, and die. It feels as if it is fuel starving. It restarts immediately and smoothly and I go on, but I don't like being in the middle of intersections with a dead engine. Can someone give me a direction to go for checking this out. Thanks.
Old Oct 31, 2010 | 09:36 AM
Wyowanderer's Avatar
Wyowanderer
First, pull the codes or have someone do it for you. If you don't, you'll be guessing from the start.
Old Nov 6, 2010 | 11:48 AM
seventysevenF150's Avatar
seventysevenF150
It's either a fuel problem ( Filter, pump, injectors ) or maybe a problem with vacuum-advance on your distributor.
bigjd
Jan 18, 2016 01:48 PM
collinrandle
16
Nov 17, 2015 01:13 AM
caere
Jun 12, 2011 08:19 PM
dougbrown
Jan 30, 2011 08:41 AM
Bimmerboy1989
Oct 20, 2005 08:24 PM
