injector cups
Old Mar 8, 2017 | 12:57 PM
  #46
Stewart_H's Avatar
Stewart_H
Originally Posted by Rikster-7700
Great point, thank you for catching my omission! EC-1 is the way to go.....
There are now H-OAT coolants that meet the EC-1 rating, so if a person wants a true Heavy Duty OAT coolant, don't just go by the Cat EC-1 rating.
Originally Posted by Stewart_H
Just a quick update:
Zerex G-05 coolant (Zerex version of the Ford "Gold") is now marketed as meeting the CAT EC-1 rating even though it is a Hybrid OAT coolant. So it looks like the EC-1 rating no longer applies ONLY to a Heavy Duty Organic Acid Tech Extended Life Coolant.
Source: http://content.valvoline.com/pdf/Zer...l_Bulletin.pdf
We can no longer tell people to just look for the EC-1 rating on the coolant now when they're trying to find a HD OAT ELC.
Stewart
I try to keep my Gooch coolant thread updated when I learn of this stuff, so don't hesitate to check that coolant thread periodically.
Stewart
Old Mar 23, 2017 | 04:57 AM
  #47
booger47's Avatar
booger47
It was a cracked injector cup. There was a 1 inch split. Thanks for all your help fellos.
Old Mar 23, 2017 | 06:42 AM
  #48
Tugly's Avatar
Tugly
That is from a loose injector. When you install the injectors and the cylinders are purged, leave the valve covers off to idle the engine for an hour or so. This gives you the opportunity to make observations on how things are operating under there, and it warms the engine up. Once the engine is warm, re-torque your injectors to factory specs.
Oh... and with the VCs off, the intercooler tubes and turbo is open. Make sure all paper towels, rags, gloves, lint, and house pets are a minimum of 1 block away from the turbo and engine intakes. If you start it, it will suck.
PaysonPSD
37
Mar 6, 2020 05:29 PM
Ford.Dude
Dec 5, 2017 06:53 PM
gaffmedic
Aug 12, 2016 01:12 PM
MK_snipe
Jun 28, 2016 08:44 AM
creator
Mar 28, 2016 07:39 PM
