Newb Needs Help Deciding
Old Oct 30, 2010 | 05:51 PM
jeronlines's Avatar
jeronlines
I've been looking for awhile and am considering a 2000 LTD, 7.3 PSD, 160k miles, 1FMSU43F2YEC33330. I ran the VIN- no outstanding recalls. The AutoCheck is clean and I had a dealer run the oasis report. It looks ok to me, but I'd appreciate a knowledgeable second opinion.
Is there anything else I should be looking for when I go to drive it? Any help is appreciated!
Standard Claims List For Model Year 2000
Detailed Vehicle Specification
VIN VEH MKT BODY VER DRIVE PLT TRS ENG PROD WARR SELLING SELL TIS WCC CPSC_6 PREF BASE DIST
LINE DERIV CAB SERIES TYPE CD CD CD DATE DATE DEALER CNT SUFF CCC CD (Miles)
02- 12-
1 F,'vISFUF2YF:'C.1}.130 TIL 1 F TIWD TICA TIE Al TID8 T/DS JAN- FEB- 147496 USA 2 7KII 130101 XC3Z 10849 LA G29 42 3134
2000 2000
A WS Claim Key: 795550 Trx Code: 2 Labor Hrs: l.l
Dlr Cd-Sub Cd: * . DUSTY RHODES FORD . 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date: 16- Doc
04696 - Name. LINCOLN MERCURY, INC .. Ph. 4462351 MAR-2000 #:01012451
ICust Comments: CUST STATES TEMP GAUGE INOP I
lTech Comments: SENDING UNIT DIAG REPLACE INSTR. CLUSTER. PER HOT LINE, REPLACED TEMP SENDING U I
I
02- 12-
1 FMSU43F2YEC330 Till F TIWD TICA TIE Al TID8 TIDS JAN- FEB- 147496 USA 5 7K02 130501 F65Z 10884 AA A85 42 10551
2000 2000
A WS Claim Key: ')083515 Trx Code: 2 Labor Hrs: 0.9
D1r Cd-Sub Cd: * . DUSTY RHODES FORD . 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date: 15-JUN- Doc
04696 - Name. LINCOLN MERCURY, INC .. Ph. 4462351 2000 #:01115552
ICust Comments: CUST STATES TEMP GAUGE FLUCUATES AND IS INOP INT.. I
ITech Comments: SENSOR DIAG REPLACE COOLANT TEMP SENSOR AND CONNECTOR I
I
02- 12-
IFMSI'43F2YlT.13330 TILl F TIWD TICA TIE AI TID8 TIDS JAN- FEB- 147496 USA 5 7H06 120300 * 19700 , C02 42 10551
2000 2000
A WS Claim Key: 2083534 Trx Code: 2 Labor Hr.: 0.6
Dlr Cd-Sub Cd: ' . DUSTY RHODES FORD . 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN- Doc
04696 - Name. LINCOLN MERCURY, INC .. Ph. 4462351 2000 #:01115551
ICust Comments: CUST STATES AC NOT COLD I
ITech Comments: DIAG DIAG PRESSURE TEST NO LEAKS, EV AC AND CHARGE ADD DYE I
I
02- 12-
IFMS1H3F2YEC33330 TILl F T/WD TICA TIE Al TID8 T/DS JAN- FEB- 147496 USA 9 7S02 180102 , 14401 , G29 42 20559
2000 2000
lAWS Claim Key: .1896317 Trx Code: E83 Labor Hrs: I
Dlr Cd-Sub Cd: ' . DUSTY RHODES FORD . 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date:25-0CT- Doc
04696 - Name. LINCOLN MERCURY, INC .. Ph. 4462351 2000 #:01262251
ITech Comments: CONNECTION DIAG TRACE WIRING FOUND TERMINAL AT TEMP SENDING UNIT I
I
02- 12-
IFMSU43F2YECD}30 Till F TIWD TICA TIE Al T/D8 TIDS JAN- FEB- 147496 USA 31 2G02 030701 F7TZ 12K073 A E29 42 44032
2000 2000
lAWS Claim Key: 17373260 Trx Code: S07 Labor Hrs: 2.7
D1r Cd-Sub Cd: 02817 -' Name: TERRE HAUTE FORD, INC. Ph: 812- St:IN Ctry Cd: USA RegCd: NA Repr Date:05- Doc
2344831 AUG-2002 #:04380601
ICust Comments: CUSTOMER STATES CHECK ENGINE LIGHT ON DIED AND WOULD NOT RES TART THIS WEEKEND, WENT BACK THIS I
ITech Comments: DIAGNOSED AND REPLACED THE CAMSHAFT POSITION SENSOR I
I
02- 12-
I FMSU4.'F2YEC33330 TILl F TIWD T/CA TIE Al T/D8 TIDS JAN- FEB- 147496 USA 35 2E03 031401 XC3Z 12B599 AA D02 42 50332
2000 2000
A WS Claim Key: t 9225235 Trx Code: En Labor Hrs: 4.2
Dlr Cd-Sub Cd: 02817 -' Name: TERRE HAUTE FORD, INC. Ph: 812- St:JN Ctry Cd: USA Reg Cd: NA Repr Date:27-DEC- Doc
2344831 2002 #:04731901
ICust Comments: CUST STATES THAT THE VEHICLE AFTER ABOUT 4 MILES IT LOADS UP AND HAS NO POWER,CHECK AND ADVISE I
Tech Comments: DIAGNOSED AND REPLACED THE EXHUAUST PRESSURE CONTROL VALVE AND THE BACK PRESSURE SENSOR,ALSO REPLACED THE
INJECTOR
I
02- 12-
I FMSU4.'F2YEC3333fJ TILl F TIWD TICA TIE Al TID8 TIDS JAN- FEB- 147496 USA 36 2GOI 031401 YU7Z 12A650 AA D50 42 50644
2000 2000
I https://web.cudl.dealerconnection.com/Warranty/CuDLA WSReICl.asp?modelyr=2000&v... 10/3012010
Claims List Report Page 2 of 2
lAWS Claim Key: 19439488 Trx Code: En Labor Hrs: 1.5
D1r Cd-Sub Cd: 02817-' Name: TERREHAUTEFORD,INC. Ph: 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date:20-JAN- Doc
2344831 2003 #:04777701
lellst Comments: CUST STATES THAT WHEN W ARM,LOOSES POWER, WILL NOT PULL ITSELF AND TEMP GAUGE IS NOT WORKING PRO PERL Y I
ITech Comments: DIAGNOSED AND FOUND THE PCM FAILING INTERMITENTL Y,REPLACED PCM TEST DROVE FOR 90Ml. NO PROBLEM REOCCURED I
I
02- 12-
IFMSU431'2YE03330 TILl F TIWD T/CA TIE AI TID8 TIDS JAN- FEB- 147496 USA 49 IGOI 030305 F6TZ 8575 AA D50 42 66060
2000 2000
lAWS Claim Key: 22372691 Trx Code: En Labor Hrs: 0.4
Dlr Cd-Sub Cd: 09806 -' Name: BOB BOWEN FORD, INC. Ph: 812- St:IN Ctry Cd: USA Reg Cd: NA Repr Date:29-JAN- Doc
4422000 2004 #:00114202
lellst Comments: VEH NOT WARMING AFTER 20 MILES OF I
ITech Comments: DRIVING PER CUSTOMER REPLACED THERMASTAT ENGINE WARMS UP TOO I
I
02- 12-
I FMS1H3F2YEC33330 TILl F TIWD T/CA TIE Al TID8 TIDS JAN- FEB- 147496 USA 60 2G02 0300XX F7TZ 12K073 A D50 42 84777
2000 2000
A WS Claim Key: 23669101 Trx Code: En Labor Hrs: 1.5
Dlr Cd-Sub Cd: 08142 _ * N . CROSSROADS FORD Ph: 217- St:lL Ctry Cd: USA Reg Cd: NA Repr Date:03-JAN- Doc
arne. TRUCK SLS INC 5280770 2005 #: 132746B
ICust Comments: UNIT RUNS FOR 5 10 MINUTES THEN SHUTS OFF. I
84777 PERFORMED VISUAL INSPECTION CHECKED FUEL TOPPE D OFF OIL LEVEL CHECKED INTAKE RESTRICTION PERFORMED KOEO
Tech Comments; PULLED CMDTCS P0340 P0344 TEST DROVE MONITORED PlDS FOUND UNIT WOULD DROP RPM SIGNAL USE CAM SENSOR TESTER CAM
SENSOR FAILED REPLACED CAM SENSOR RETEST DROVE. OK 5829 NOTE CHECKED FUEL MPG AT 63 MPH UNIT GETTING 14.2.MPG .5829
I
02- 12-
IFMSU43F2YEC,13330 Till F T/WD TICA TIE Al TID8 TIDS JAN- FEB- 147496 USA 100 , . * * * , , 137751
2000 2000
lAWS Claim Key: 261846"+7 Trx Code: 07S57 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 20505 _. N . VILLAGE FORD OF PINE Ph: 845- St:NY Ctry Cd: USA Reg Cd: NA Repr Date:09-APR- Doc
arne. BUSH NY, INC. 7442001 2008 #:1292480 I
I
02- 12-
IFMS1J.l3F2YEC33330 TILl F TIWD TICA TIE Al TID8 T/DS JAN- FEB- 147496 USA 120 * . * , * , , 65258
2000 2000
lAWS Claim Key: 26791023 Trx Code: 09S09 Labor Hrs: 0.2
D1r Cd-Sub Cd: 20505 _ * N . VILLAGE FORD OF PINE Ph: 845- St:NY Ctry Cd: USA Reg Cd: NA Repr Date:Ol-DEC- Doc
ame. BUSH NY, INC. 7442001 2009 #:03351501
lellst Comments: 09S09 RECALL I
I https://web.cudl.dealerconnection.co...modelyr=2000&v ... 10/30/2010
Old Oct 31, 2010 | 05:21 AM
katiesdad7's Avatar
katiesdad7
Seems like it has quite a few engine issues. It has left the previous owner stranded a few times. I would look elsewhere.
Old Nov 7, 2010 | 07:13 AM
jeronlines's Avatar
jeronlines
maybe, but i did the deed and bought it. the temp sensor is still a little tricky- needs constant attention to keep it clean. don't know if it is a bad sensor/harness or just poor location. anyway, happy so far.
footballguyxx
6.4L Power Stroke Diesel
Jun 26, 2015 05:37 AM
Sarge559
Sep 16, 2013 07:53 AM
LegacyMill
Oct 19, 2007 12:13 AM
77hiboyboy
Oct 2, 2006 02:38 AM
