Intake Manifold
Old Oct 28, 2010 | 08:18 PM
TLI's Avatar
TLI
Intake Manifold
What would the gain or loss be going to a Trick Flow Box-R or R Series intake manifold over a stock manifold if the final goal is ~400 HP in the future for a stroked 351? This would be going a F-150 4X4 that would never tow more than a light load every once in a while. It would also have 31" tires with the factory 3.55 gears and an E40D trans. The motor is stock now but I don't want to have to buy more than one manifold to reach my goals.
Old Oct 28, 2010 | 11:06 PM
Conanski's Avatar
Conanski
You'll never get anywhere close to 400hp with the stock 5.8 intake so the Trickflow is the answer. I'd select the R series over the Box as well, you do want a somewhat normal powerband after all, the Box is really only usefull for a screamer or forced induction.
Old Oct 30, 2010 | 08:02 AM
TLI's Avatar
TLI
Intake Manifold
Thanks, do you think I would need aluminum heads or do you think something like Thumper heads would flow enough?
Old Oct 30, 2010 | 09:24 AM
Conanski's Avatar
Conanski
You don't need aluminum heads but you do need a set that flow about twice as much as the originals.. or about 250cfm/port. Options include RHS 180's and Dart Iron Eagles.
jasonickz
Mar 3, 2014 10:23 PM
Ciph3r
23
Mar 14, 2010 02:55 PM
Volfandt
1997 - 2003 F150
Sep 13, 2007 06:52 AM
the_binbuilder
May 15, 2004 01:30 PM
