Front Leaf Spring Chaos
Old 10-30-2010, 09:12 PM
fordpowerstroke444's Avatar
fordpowerstroke444
fordpowerstroke444 is offline
I have a 2000 F250 Crew Cab 4X4,7.3.My leaf springs are code U springs.I am putting a plow on it,so I searched the salvage yard website,and found a pair of code X springs(so they said)I put them on the truck and gained about 5/8 of an inch(what a waste of time).How do you know what springs you actually have.Is there a website where you can put in the part number,and it tells you what they are?Thanks in advance for any help,I will be out in my garage with my head in the vise.
Old 10-30-2010, 09:20 PM
Waltdog's Avatar
Waltdog
Waltdog is offline
of American machinists
Front Springs — F-Series
Base part number — 5310 (RH/LH)
Pre-fix — F81A
B — Suffix BA
C — Suffix CA
D — Suffix DA
E — Suffix EA
F — Suffix FA
G — Suffix GA
H — Suffix HA
I — Suffix RA
J — Suffix SA
K — Suffix TA
L — Suffix UA
Pre-fix — 1C34
S — Suffix AAA
T — Suffix ABA
U — Suffix ACA
V — Suffix ADA
W — Suffix AEA
X — Suffix AFA
Front Springs — Excursion
Pre-fix — YC35
G — Suffix G
H — Suffix H
S — Suffix S
Pre-fix — 1C34
AG
AH
AJ
You can use the above numbers to decode spring ratings
Old 10-30-2010, 09:42 PM
fordpowerstroke444
The numbers and letters on one of the springs is 2C34AFA,followed by RPN2662.So these are actually X code springs.They are 2 leaf.Ive seen some posts saying that X code springs are 3 leaf.Thanks a million for your code breakdown.YOU ROCK WALTDOG.
Old 10-30-2010, 09:43 PM
fred258's Avatar
fred258
fred258 is offline
spring upgrade
hey Walt when I bought my 250 the previous owner said he had the springs upgraded at a local shop that specializes in just that sort of job. He also told me the springs were now at a 1 ton rating and the truck had gianed about 2 inches of lift with the job. So my question is how will I know if I am able to install a plow? I have purchased a Myer power angle with a 8.5 ft blade used so I hope you can help me figure this out.
Old 10-31-2010, 12:32 AM
Waltdog's Avatar
Waltdog
Waltdog is offline
Glad you got it figured out!
I have no experience with plows so I cant really help you. If you have more than 2 leaves up front than the PO had some spring work done.
Here is a link from Myer's site, you can input your model number and perhaps get some installation instructions
Meyer Products: Service Manuals & Installation Instructions
BLDTruth
05-25-2016 04:33 PM
ZackYoung
1999 to 2016 Super Duty
06-30-2015 07:07 AM
carl2591
06-14-2015 06:03 AM
joegeds
06-02-2014 12:38 PM
gvagolf
11-01-2013 06:52 AM
Quick Reply: Front Leaf Spring Chaos
