Deactivating automatic door close
Old Oct 29, 2010 | 08:31 AM
omegalita's Avatar
omegalita
Swissnavigator
Hi
does anybody know how i can reprogramming the nervy "automatic door closer"?
Old Oct 29, 2010 | 09:15 AM
alloro's Avatar
alloro
If you mean the autolock feature then here's the instructions from your owner's manual...
Deactivating/activating the autolock feature:
Before following the procedure, make sure that the ignition is OFF and all vehicle doors and the liftgate window are closed. You must complete steps 1-5 within 30 seconds or the procedure will have to be repeated. If the procedure needs to be repeated, you must wait 30 seconds.
1. Turn the ignition key to ON.
2. Press the power door unlock control three times.
3. Turn the ignition key from ON to OFF.
4. Press the power door unlock control three times.
5. Turn the ignition back to ON. The horn will chirp.
6. Press the unlock control, then press the lock control. The horn will chirp once if autolock was deactivated or twice (one short and one long chirp) if autolock was activated.
7. Turn the ignition to OFF. The horn will chirp once to confirm the procedure is complete.
Old Oct 29, 2010 | 09:35 AM
omegalita's Avatar
omegalita
Swissnavigator
Thank you very much.
I did'nt know that this procedure is described in the owner manual. For my Explorer it was a hard work to find such a "programming-code"...
EDIT: Just made the reprogramming and works fine!!!!
Old Oct 30, 2010 | 03:16 AM
omegalita's Avatar
omegalita
Swissnavigator
By the way...are there more "reprogramming-codes" for other things?
In my owner manual i can't find anything about this codes....
Old Oct 30, 2010 | 10:40 AM
alloro's Avatar
alloro
Download a PDF version of your owner's manual at the link below. Having this gives you the ability to search.
https://www.fleet.ford.com/maintenan...ls/default.asp
gore
Oct 22, 2016 10:58 AM
Joshs 93
Jul 6, 2016 08:21 PM
lewain
2015 + Expedition & Navigator
Apr 10, 2016 07:28 PM
Paul_Bukowski
2015 - 2020 F150
Sep 9, 2015 04:30 PM
lhud
Aug 15, 2015 03:08 PM
