Truck acting weird ! Running rough
Well i was driving my truck " 00 F450 7.3L " and i noticed the truck started to act weird , it started to run rough , truck seemed like it was missing fuel .. like you could hit the gas pedal and no power at all. Well after a few seconds truck died.
I took to the dealer and paid a diagnostic of $195 .. they called and gave me an estimate of $2100 to replaced Orings and the fuel bowl ! They said there is a leak on the bowl , and the injectors are leaking also. I went there and i noticed the truck was still sitting at the same spot , tryed to look for the leak on the bowl couldnt find it.
Any help ? i dont believe on their diagnostic at all i mean i dont think a leak on the bowl could cause all this ? Unless all the seals on the injectors when bad on all injectors at the same time which no way in hell could have happened .. Any help ?
Check engine light is off. Cant read any code with my computer
If you do have any leaks, this is the guy to get them from, bob at guzzles. Replacement O-rings for Ford Diesel Engines I dont believe that the leak unless quite severe would cause this but there is a possibility of the O-rings giving you an issue, is there any oil present in the fuel filter? If so injector HPO is leaking into the fuel which will give you some issues.
But if you only give bits and pieces of your issue in several different threads, we'll soon have you chasing your tail.
well im a new user of this thing so i dont really know how to delete or continue with the same thread to be honest ... I recently replaced the HPOP and the Fuel Injector Regulator ... and the truck drove fine for a few days and then now it started this new problem. Truck now takes a while to start and when finally starts , runs rough and then die after a while.
Im going to check tomorrow to see if there is any oil in the fuel filter .. what other things should i check for ? i really dont believe on their diagnostic .. i feel like this could be a simple problem and they are just trying to rip me off ..
Hey i got it to start and drove for a few days.... but i couldnt get to start this morning it seems like the glow plugs are working ...
I left plugged with in all night and when i went to start this morning the temp was still COLD level , i noticed my intake heater is not working and that there is no smoke comming out of the muffler at all while cranking
How do i test the glow plug relay ? which one of the two is it ? and if it is working how do i test my glow plugs ?
thanks
thanks
