Dropping the EX
Old Oct 28, 2010 | 02:41 PM
ccbrett's Avatar
ccbrett
Dropping the EX
Well guys I am going to lower my EX its just too much for the Wife and my Black lab will not jump into it. It is currently 8 in it has a leaf lift in back with factory ford 3 in block and 8 in fabtech springs in front my idea is to remove the 3 in block from the rear and add 5 in lift front springs to replace the 8 in ones. and run 315 75 16 any input would be greatly appreciated. Thanks
Old Oct 28, 2010 | 11:24 PM
jhooch's Avatar
jhooch
It will most likely be 6-inch springs in the front, they usualy come in 4 or 6. It may require a different track bar bracket and pitman also. Good luck.
Old Oct 29, 2010 | 09:27 AM
402xjeeper's Avatar
402xjeeper
I ran this setup on my old 04 f250 6.0 cc shortbed using procomp springs, we did the install for an article in OffRoad magazine back in 04, the things to look out for are parking brake cable issues(without a block the cable may rub on the spring), some manufacturers use 4" lift springs for a pickup as 6" Excursion springs. I would use 4" pickup springs, I found that 4" procomp springs lifted the then new 04 6.0 cc fx4 f250 5" inches in front, Fabtech springs tended to settle more, but rode well,as did superlift. A 4.5 inch hanger kit and new xcode ford springs would also be in the ballpark. 2" hangers could be used if 4" lift springs were to low, but these combos are all faily tall.
Old Oct 29, 2010 | 12:32 PM
ccbrett's Avatar
ccbrett
Thanks for the info im going to take a good look at the springs and see if there are any kind of part numbers also.
jayjjcc
Mar 13, 2014 03:25 PM
4x4x
Jun 22, 2013 03:47 AM
precisiontile
Feb 10, 2013 11:22 AM
jeeplj8
Mar 23, 2012 10:52 AM
jeeplj8
Mar 17, 2011 07:08 PM
