EFI 460 TIMING AVDANCE
Old Oct 28, 2010 | 01:37 AM
jeremy2008's Avatar
jeremy2008
I just bought this coil Ford TFI Coil, Street Fire - 5527. I wanted to know how far i could advance my timing an increase my plug gap to get the most out of the coil. If this helps i use NGK V-Power® Spark Plugs ford my spark plugs.
Old Oct 28, 2010 | 01:20 PM
Bear 45/70's Avatar
Bear 45/70
A hot coil is pretty much a waste when you already had more ignition than any street motor needs, except a full race motor.
This coil does NOT allow you to change anything if you timing was already set to optimum. Otherwise you were sold a bill of goods so they could get your money.
Old Oct 28, 2010 | 02:58 PM
jeremy2008's Avatar
jeremy2008
so stick with stock gap an set timing between 10-14 btdc.
Old Oct 28, 2010 | 03:08 PM
Bear 45/70's Avatar
Bear 45/70
Yes, the problem with EFI is that without a monerting system you can only hope the timing is good under power.
Old Oct 28, 2010 | 11:36 PM
OldRacerGuy's Avatar
OldRacerGuy
I just tuned my 92 using Ford racing 9mm plugwires, an msd 8227 coil, napa cap and rotor and autolite plugs gapped at .050. I did everything but the coil at first, cause I didn't think it needed a coil until I saw the terminals. Anyway, the basic tune made a difference, but I could actually feel a difference when I got the coil installed, kinda surprised me.
Make sure your wires are good, and I'd gap the plugs a .050. Worked for me.
Old Oct 29, 2010 | 12:33 PM
jeremy2008's Avatar
jeremy2008
Yea i have 8mm plugwires ill give that a try just to c how it works.
sixofspades
33
Dec 25, 2023 10:28 PM
Spidermanmike
Apr 26, 2017 07:57 PM
Telestar
15
Jun 10, 2016 06:50 PM
joe f350
Jun 20, 2011 08:06 AM
b4hntn
1978 - 1996 Big Bronco
18
Jun 7, 2011 08:43 PM
