6637?
Old Oct 29, 2010 | 10:52 AM
triskadek's Avatar
triskadek
Going with ABS or PVC, the OD seemed the problem to me. I believe the ID of a "4 inch" ABS is going to be of "Nominal Pipe Size", so will depend on the schedule. A schedule 40 4" pipe should have an OD of 4.5" and wall thickness of .237". I would also say if you're going to try plastics, the ABS has a higher melting temp than PVC, and might stay more resilient/less brittle over time.
If you really want to be ghetto...you can burn your bridge with the old airbox and cut the tube section off from the rest of the top, and really de-burl it. Fits well into the 6637.
I think what you really want is a "tube" not a "pipe" with a 4" OD. The tube should be so thin the ID will be very close to 4".
Old Nov 29, 2010 | 01:10 PM
omc124's Avatar
omc124
MHammer21, how much were you trying to sell your s&b intake for if you still have it?
Old Nov 30, 2010 | 10:08 AM
superduty4x4's Avatar
superduty4x4
3" ABS coupler = 4" OD.
Old Nov 30, 2010 | 11:04 AM
chicagodragon's Avatar
chicagodragon
pep boys has 4'' polished alum 45's for about $20 on the shelf. look around the ricer isle. my friend just bought one for his 6637
Old Dec 1, 2010 | 10:01 AM
MHammer21's Avatar
MHammer21
Hi OMC,
Decided to keep the Kit. Thanks for asking...
acf6
Sep 14, 2011 08:15 PM
bman49
Feb 1, 2011 03:38 AM
Boxcarracer944
Oct 28, 2009 06:59 AM
Bobdad45
2004 - 2008 F150
17
Aug 3, 2007 11:05 AM
CBSuperduty
Nebraska Chapter
Mar 15, 2006 03:09 PM
