A quick Question might be a bit dumb
Old Oct 27, 2010 | 08:07 PM
redrock233's Avatar
redrock233
Have a 04 f250 just done egr delete new oil cooler, turbo overhaul, injectors overhauld. The question is in the throttle housing the butterfly valve thats in there to help with back pressure would it hurt to remove the valve. Just something to think about since it was removed in the newer models.
Old Oct 27, 2010 | 08:12 PM
Young Gun's Avatar
Young Gun
IIRC you will need a tuner to turn off teh CEL when you remove the butterfly.
Old Oct 27, 2010 | 08:23 PM
redrock233's Avatar
redrock233
Now what does that all mean, what kind of tunner will i need to do that. Also what affect will that have on performance when it is all complete.
Old Oct 27, 2010 | 08:48 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
You can buy the parts from an 05 to remove the butterfly valve. From what I understand, it should just bolt on.
If you haven't had a CEL thrown from your EGR delete, then no worries.
Not sure what words to use in the search for the topic of changing the parts for the 05.
Maybe someone will step in and give you a link.
Old Oct 27, 2010 | 09:14 PM
redrock233's Avatar
redrock233
Ok thanks hope someone will chime in. What is the eger cel though. Thanks
Old Oct 27, 2010 | 09:27 PM
amdriven2liv
Some 04's don't throw or set a "Check Engine Light" ( CEL ) when you delete or unplug the EGR valve. If you haven't had your CEL come on, you must have one that wont set the code.
My 04 does set the CEL.
05's and up will.
Old Oct 27, 2010 | 09:32 PM
redrock233's Avatar
redrock233
Ok now i know what you mean. The truck does not throw a CEL on there when egr unplugged. So does anyone else know how it will effict performance good or bad
Old Oct 27, 2010 | 09:40 PM
bradyracing's Avatar
bradyracing
You can remove the two screws holding the throttle blade and remove it. It won't throw a light but will throw a code for insufficiant EGR flow. It did on my 04 anyhow.
Old Oct 27, 2010 | 09:54 PM
amdriven2liv
Duh! Man, I forgot about just taking the elbow off and removing the stupid plate! Just don't drop those little screws in there. I used a vice grip against the side of the housing to keep the plate flat while I removed the screws.
Old Oct 27, 2010 | 10:00 PM
moebdick's Avatar
moebdick
What benefit is there to removing the butterfly valve?
Old Oct 27, 2010 | 10:35 PM
bradyracing
Unrestricted air supply at all times and no soot being sucked into the engine.
Old Oct 27, 2010 | 10:40 PM
moebdick's Avatar
moebdick
Do all 2004s throw a code if you remove the butterfly? I'd like to get rid of soot and have unrestricted air supply at all times, but emissions inspections are required where I live.
Old Oct 27, 2010 | 10:53 PM
bradyracing
I heard that 04 CA trucks would throw a light if you screwed with the EGR or removed the butterfly but I ran with EGR unplugged for a short time and than ran two EGRs and the removed butterfly and no light. The code will be there in the background but no light. Can't say what will happen with an emissions inspection in TN. Never lived in a state that cared about that yet.
Old Oct 27, 2010 | 10:54 PM
hwybee22's Avatar
hwybee22
I installed an AFE bladerunner intake in which I had to remove the throttle plate that reminded me of losing an engine brake. Once you take your foot off of the throttle, it just coasts. It feels like I can coast forever now and see how they say how you can get such great MPGs......... by only coasting. Lol
Old Oct 27, 2010 | 11:02 PM
High Binder's Avatar
High Binder
If you just block off the EGR is there any benefit to removing the plate?
