Door lock codes
Old Oct 26, 2010 | 10:01 PM
VCEC71's Avatar
VCEC71
Door lock codes
Can anyone tell me where to find the doorlock codes? I bought a used 2004 F250 Powerstroke it had no owners manual or card.
Old Oct 26, 2010 | 10:27 PM
bubba_78363's Avatar
bubba_78363
Go back to the service departmernt and ask them to do alittle researched base off your VIN number. Should have them to you in not time at all.
Last edited by bubba_78363; Oct 27, 2010 at 10:13 AM. Reason: correcting a drunk post
Old Oct 26, 2010 | 10:47 PM
bismic's Avatar
bismic
Try these:
There are three ways to find the code. One is a lot easier than the other and much less work if you have a good eye and great flashlight. There are some Excursions, F250 and F350s that have a different wiring system.
The first location to look is just above the right front kick panel; the RAP module is black in color with the numbers on the front (the same as the white module). If you look above the kick panel you can see it quite clearly without taking anything apart. If it is not at this location please follow the next step.
This part is not hard to do. You will need to remove the front cover under the steering wheel that says fuse box. (It has 4 plastic screws to remove) under the dash, the five (5) digit code is on the cream/white box behind the radio, look to the top right of the open fuse box cover through the wires. (towards the fire wall). At the back firewall, look for a 5 digit code on a sticker on a cream/white box. This is not easy but if you try every angle I promise it will appear don't forget to use a very powerful flashlight if you want to see it.
Note: The RAP module sometimes is covered by insulation making it almost impossible to see.
It is located on the firewall behind the radio just below the windshield.
The third way is a more time consuming job because you have to remover the stereo.
Once you do, look to the rear you'll be able to see the 5 digit code very easy. This process can take 2-10 minutes.
Also:
You will have to release the compartment on the right side of the steering wheel in your dash. Then there will be some insulation that you will have to push to the side. There will be a little black box on the firewall with a 5 digit number. I believe the number is printed on a white label. This is the factory code. Once you have that, you can enter it in then press the 1-2 and 3-4 buttons at the same time then enter in your own code. The truck will lock then unlock if you've done it right. Oh yeah - you have to do each step within 5 seconds of each other for it to work.
Old Oct 27, 2010 | 05:18 PM
shinyconcrete's Avatar
shinyconcrete
Does anyone have the list of number combinations that you can go through and try?
Old Oct 27, 2010 | 05:36 PM
SteveBricks's Avatar
SteveBricks
FTE Leadership Emeritus
FTE Emeritus
No offense, but if there is such a thing I hope nobody posts it.
Our trucks are vulnerable enough as it is.
Old Oct 27, 2010 | 05:43 PM
shinyconcrete
I know what you mean, but it is just a list of the obvious possible combinations of the 5 numbers on the keypad. Someone had one they made up a while back. It takes a little time to go through.
A pm or email would work for me.
Old Oct 27, 2010 | 05:48 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE VCEC71, bubba and shinyconcrete. You can try this, read through our Tech Folder located at the top of the forum. Scroll down to the very bottom and you will see Keyless Entry Code
If anyone wants SteveBricks code.....just let me know and I will Private Message it to you...
Old Oct 27, 2010 | 07:15 PM
Sullid01's Avatar
Sullid01
I used the info I found here on FTE - I found the easiest way was with a dental mirror and a flash light. I looked up in an area under the dash just behind the radio (it's about a foot up there). I found the numbers impossible to read without the mirror - no matter how much I dug around, my head just would not get in the right position. Ford will want about $100 to get this for you (unless they really like you).
Old Oct 27, 2010 | 07:25 PM
hubler13f's Avatar
hubler13f
My truck came with a keyless entry code card in the owners manual, but it doesn't have any key pads, figure that one out, I'm still scratchin my head about it.
Bluebomber94
Nov 11, 2017 10:20 PM
i eat hybrids
May 20, 2017 10:15 PM
kbf1961
Oct 17, 2015 10:05 PM
88 250
Dec 24, 2010 04:14 PM
Miketnf150
1978 - 1996 Big Bronco
Aug 21, 2002 12:57 PM
