1978 - 1996 Big Bronco
Computer Code 22
Old Feb 25, 2003 | 04:31 PM
Schlump's Avatar
Schlump
Computer Code 22
I pulled the codes on my '89 I6. The KOEO test showed a 22 seperated by a single flash and another 22. The KOER showed 11's. The idle has been intermittently rough on start-up, but no real pattern to this. I cleaned the throttle body and it seems to perform better (maybe it is wishful thinking !) I did not clean remove and clean the IAC as I am having problems finding a gasket for it, short of buying a whole IAC, and have been to lazy to tap one out. The resistance check on the IAC however showed it was fine. Is this indicative of the BAP/MAP sensor?
Old Feb 25, 2003 | 10:18 PM
tite4x4's Avatar
tite4x4
Computer Code 22
Code 22 is the MAP sensor. had to replace mine two days ago. they are not cheap. I had payed like $58.
Just curious as to what your symptoms were in order for you to start getting code 22.
Old Feb 26, 2003 | 05:57 AM
Schlump's Avatar
Schlump
Computer Code 22
My symptoms have been an occasional rough idle on start up. It happens only every so often and there does not seem to be a pattern to it. It clears with in a minute or so, I usually start driving and about a 1/4 mile down the road you can feel it clear and the power pick up where it is supposed to be.
Old Feb 27, 2003 | 11:49 PM
steve83's Avatar
steve83
Computer Code 22
I collect MAPs (and lots of other stuff) from junkyards. My whole truck is built from junkyard parts, and it's more reliable than my sister's '94 Tahoe. Most junkyards will let you take little electronic parts if you're buying something bigger that they normally sell, so check around. If a used one clears up the problem, you'll know what it is. If it doesn't, you haven't spent much trying it, and you have a spare.
kentuckyredneck
15
Sep 21, 2010 09:22 PM
i eat hybrids
Modular V10 (6.8l)
16
Mar 7, 2008 07:21 PM
someday
Jan 8, 2008 09:37 AM
