STC Maybe?
Old Nov 2, 2010 | 01:12 PM
PowerstrokenAL's Avatar
PowerstrokenAL
That looks like what you need. This kit has the EGR cooler O-ring so when you take everything loose you can replace it.
Old Nov 2, 2010 | 01:15 PM
PowerstrokenAL
I'm not familiar with the bypass kit. It says its has the screen included I didn't see a picture of it but I'm sure if the description says its in there it is.
Old Nov 3, 2010 | 09:17 AM
mblanken881's Avatar
mblanken881
OK, so I performed a couple of tests and the truck passed all of them. The degas bottle has no white residue, the inside of the degas bottle does not look extra clean like it was steam bathed, and I parked the truck on an incline overnight and checked the egr valve this morning. No coolant at all on the valve or in the cooler.
Is there another way to check the egr cooler for failure or could the white smoke be due to something else? Could the white smoke be from the STC going bad? I would like to make sure I am replacing the correct part.
Old Nov 3, 2010 | 03:34 PM
mblanken881
OK. The last two days for work I have had ~4 hr stints where I'm either idling or very slowly moving. After that when I go back to normal driving I have a considerable amount of white smoke blowing out of the exhaust for about 3-4 minutes. I know, I know, you're not suppose to idle these trucks. I normally dont but the last two days was an exception for work and won't happen again in the future.
Old Nov 3, 2010 | 03:50 PM
bismic's Avatar
bismic
You don't check it on an "incline", you check it on a "decline".
Old Nov 3, 2010 | 04:48 PM
mblanken881
Sorry, used the wrong term. The nose of the truck was pointed downhill.
Old Nov 4, 2010 | 06:22 PM
PowerstrokenAL
No more test that i know of. My buddies truck was smoking like that and come to find out he had a head gasket leaking. He was experiencing "severe" white smoke and of course the tell, tell sign running hot. I would keep watch on the temp to make sure its not running over half way.
You could drain some of the coolant from the driver side (radiator plug) catch it in a clear type bucket and take a look at it to see if there is any better signs of oil in it. This doesn't sound like a oil cooler from our experience.
Does it smoke just at cold starts?
Old Nov 4, 2010 | 06:44 PM
mblanken881
Only on cold starts first thing in the morning or after long periods of idling.
Old Nov 4, 2010 | 07:22 PM
PowerstrokenAL
Usually "blue smoke" is raw fuel but normally not really noticeable except when temps are falling or at start up. I had this happen to me and my FICM was going out. Mine would pour "blue" smoke out and smell like raw fuel for 3-4 miles.
And you did say it was "white" smoke correct?
This sounds like coolant burning off through the exhaust which is signs of the EGR cooler but you didn't see coolant in the EGR valve housing. When you pulled the EGR valve was it gunked up? One more thing to look for and its a little difficult to notice but pull the oil stick and see if it looks like any coolant maybe mixing with your oil. Ususally when the EGR cooler goes out you will get water in your oil along with white smoke, when was your last oil change? Just wondering if it looked milky? A small leak on the EGR is kind of hard to notice until the thing finally kicks the bucket.
Oil Cooler is oil in the degas! Sounds like you are ok there.
Just a small tip if you start noticing the white smoke severely I would pull over and tow it back home rather than taking a chance. If you are driving and it goes out and you don't notice it you "could" blow the head gaskets really fast without knowing. Just keep caution in your passengers mirror and your temp gauge.
Again though it could be early signs of head gaskets OR EGR cooler. IMOP one of the two are leaking some what.
Old Nov 4, 2010 | 07:42 PM
PowerstrokenAL
Forgot to mention though you should be loosing small amounts of coolant in the degas bottle though if this is happening.
Old Nov 4, 2010 | 07:53 PM
mblanken881
The coolant was a little low on Monday. I filled it up and it hasn't changed since.
Yes, it is 'white' smoke. The egr valve wasn't gunked up, it just had the typical coating of soot on it. I changed the oil 1500 miles ago and the oil looked just like it should not milky at all. But I wasn't having the smoking issue then. I will check the dipstick tomorrow.
I have a scangauge 2 on the way from Autozone. I will post my EOT vs. ECT and all codes if any.
Thanks for all your help
Old Nov 4, 2010 | 08:27 PM
mblanken881
I was just reading a little on the FICM. I read that a sign of a bad FICM was rough running on a cold start. Well, since it's gotten down to the high 20s low 30s for lows overnight around here my truck runs a little rough right at startup first thing in the morning. Maybe the smoke is coming from the FICM? I'll check it's voltage this weekend.
Old Nov 4, 2010 | 08:53 PM
  #28
PowerstrokenAL
I replaced mine about 10 months ago. It got cold in the 30s-40's here and I started having white smoke. We drove the truck to TN where it got in the teens. I started having trouble with mine not wanting to crank. It would buck/jerk/skip etc.... it got so bad smoking it looked like i was spraying fog out the exhaust. My smoke again though was heavy blue colored and smelt heavily of diesel. I replaced mine and now the truck fires up as if you have just gotten out of it warm.
Yes the voltage check is a good idea just to rule that out. I got the 58volt hot flash from Swamps and it drove like a new truck. I have two buddies that have the 6.0 and theirs are running rough at cold crank.....bucking about 50-55 mph until warmed up.
As for the white smoke issue though with the coolant being a little low I would keep a close eye on it.
Old Nov 4, 2010 | 09:01 PM
  #29
PowerstrokenAL
Crack your window about half way before turning the key over, listen carefully and see if you hear the injectors making noise. I totally over looked this when my FICM was showing out. Mine was silent, i would turn the key over and you wouldn't hear anything coming from under the hood. I had to actually plug my truck in overnight to get it to fire the next morning there at the end of my FICM.....R.I.P.!! They make a ticka, ticka, ticka noise....sorry bad example but you should hear them right before the wait to crank light goes off.
I know yours can't be that bad yet, mine was toast!
Old Nov 4, 2010 | 09:06 PM
  #30
mblanken881
Whats the best way to insure my batteries are at full capacity before checking the FICM? Does O-Reilly's battery test work?
