steering gear box replace or rebuild
Old Oct 25, 2010 | 05:40 PM
82airborne82's Avatar
82airborne82
ok Ive traced my steering problems to my gear box heres whats happening there is too much play in the steering and when I grab the steering shaft I can turn it easily and the tires move real easy back and forth too so I am thinking it is a seal or something in the gear box. the truck is a 77 f250 4x4 does can anyone tell me if rebuilding this thing (or trying to) is worth it or should I just shell out the few hundred bucks and buy a remanufactured one? also here is another strange thing, the steering wheel rotates like 2 1/2 to 3 turns for left and only like 1 1/4 for right??? what is that all about? the tires arent rubbing against anything its just the steering it wont let me turn right its a real pain in the *** trying to park this thing any help is greatly appreciated thanks have a great day
Old Oct 26, 2010 | 02:43 PM
HIO Silver's Avatar
HIO Silver
IMO, get a remanufactured unit. Sometimes the apparent cost savings isn't worth the headache it may cause.
Just get it over with and you can move onto something more "fun".
Old Oct 26, 2010 | 05:03 PM
Roller150's Avatar
Roller150
Get a new box, dont bother trying to rebuild. Its very difficult and can be dangerous if you dont know what your doing.
Old Oct 26, 2010 | 05:04 PM
ford390gashog's Avatar
ford390gashog
You can rebuild it. But all you can get new is the seals and gaskets if any hard parts are worn you are out of luck. So its a crap shoot much better to just get a reman with a warranty and be done with it. And if you have never worked on recirculating worm drive gears before it is wise not to try it. They can jam up and cause the steering wheel to lock in turns.
Old Oct 27, 2010 | 06:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Does this 1977 F250 have P/S or M/S? Is this F250 4WD a High Boy...or not?
1977 F250 4WD's assembled before serial number Y20,001 (High Boys) do not have a P/S gearbox. These trucks have Power Assist P/S.
The manual gearbox is used, since it has nothing to do with the P/S system. It uses a separate P/S control valve and ram cylinder.
1977 F250 4WD's assembled from serial number Y20,001 are not High Boys. Have Ford integral P/S.
If you have this type: redheadsteeringgears.com.
Go to their website and read how they fix the built-in flaw all these Ford integral P/S gearboxes have.
An autoparts store so-called rebuilt gearbox is nothing more than a resealed gearbox.
There are no new gearboxes available = obsolete.
btw: Since these trucks have a rag joint, it might be defective and the reason why the steering shaft is loose.
Old Oct 27, 2010 | 08:38 AM
82airborne82
sorry forgot to mention its not a highboy and does have power steering thanks for all the input guys
Old Oct 27, 2010 | 08:40 AM
82airborne82
how would I be able to tell if its a rag joint or not? I can twist the steering shaft by hand fairly easily and the tires move with it if the truck is jacked up not to mention the problem im having with the turning radius wich is horrible when making a right turn, what is that all about?
Old Oct 27, 2010 | 09:05 AM
eviiltim72's Avatar
eviiltim72
Everything I have read says go with the redeadsteeringgears.com units. I have replaced several with auto zone, discount auto and even o'reilly parts and they just don't last but about a year, two if your lucky. I plan on buying one from them myself for my truck next spring.
mfhull
May 4, 2021 10:43 AM
Brian Donoghue
Jan 25, 2017 03:48 PM
Sparky83
15
Apr 16, 2016 12:36 AM
Junx69
Feb 1, 2012 06:56 PM
82airborne82
Sep 29, 2011 09:49 PM
