Motorcraft 2150 accelerator pump question
Old Oct 25, 2010 | 09:38 PM
wyckedcombo17's Avatar
wyckedcombo17
Hey FTE,
I'm rebuilding my carburetor at the moment (for my 1978 400 M/T F250), and when I checked the sheet for the specs of the accelerator pump overtravel lever and it confuses me. This is what the sheet says in the carb kit
78 351" M F100.........49S M/T.........POL: 3.......CHOKE SETTING: INDEX
351" M F150/250...CAL M/T.........POL: 4...............................INDEX
351" M F350.........CAL M/T.........POL: 4...............................2-RICH
400" F150/250......CAL A/T..........POL: 3...............................INDEX
Heres the confusing part: when I pulled the carb, the pump overtravel lever was in the "4" position, and the auto choke was set in the "2 RICH" which is what it says on the valve covers. Should I tune my carb to the 351M F350 settings?
What do you have yours in if you have a '78 400 manual? Is mine different because it was made in Canada?
I searched the forum and didn't find a definitive answer, but if you can find one, please give me the link
Old Oct 25, 2010 | 10:17 PM
steponit's Avatar
steponit
what is the carb # ?
Old Oct 25, 2010 | 10:28 PM
wyckedcombo17
D7TE CUA
I edited my last post by the by I misread the sheet
Old Oct 25, 2010 | 11:44 PM
thatsrealnice's Avatar
thatsrealnice
We have the same exact carb. The accelerator pump on mine is dripping fuel onto the intake manifold, debating on whether to do a rebuild, or to repair just the pump. I'm not sure what mine is set on right now, I can go take a look at it tomorrow, but I don't know a lot about carbs.
Old Oct 26, 2010 | 08:09 AM
wyckedcombo17
thatsrealnice, what do you have in your truck? Engine, trans?
Old Oct 26, 2010 | 10:38 AM
thatsrealnice
I have a 400 with a NP 235 4 speed.
Old Oct 26, 2010 | 03:22 PM
wyckedcombo17
F250? Do you mind taking a look if so?
Old Oct 26, 2010 | 04:51 PM
thatsrealnice
Mine is in the number 4 position. Can't tell about the rich setting. I'd just go with what's on the valve cover tag.
Old Oct 26, 2010 | 06:00 PM
steponit's Avatar
steponit
Go with Position #2
Old Oct 26, 2010 | 09:46 PM
wyckedcombo17
steponit, why kind of truck do you have? I'm looking for someone with a 400 4spd F250, non-California
Old Oct 26, 2010 | 11:05 PM
steponit's Avatar
steponit
I got the info from Mil1ion on another site
He has a massive amount of ford literature,so I would trust his info to be correct
Old Oct 27, 2010 | 06:45 AM
wyckedcombo17
Do you have a link? I also need the float adjustments and everything too.
Old Oct 27, 2010 | 01:28 PM
steponit's Avatar
steponit
google his name
POL_Sarge
Apr 12, 2016 08:29 AM
matt2491
Mar 31, 2016 11:13 AM
POL_Sarge
WTB - Parts & other
Sep 28, 2015 10:01 AM
sigepsbbj
Sep 5, 2015 06:11 PM
bjorn773
19
Nov 24, 2004 10:43 PM
