Head Bolt Question
Old Oct 25, 2010 | 09:01 PM
cheezit's Avatar
cheezit
naw I wasnt scared at all _
Old Oct 25, 2010 | 09:22 PM
HeavyTow's Avatar
HeavyTow
Looking for anyones opinion. If you have a very low mileage truck, you fix the head gaskets, use good head bolts/studs, egr cooler is good and you don't modify for more hp, but plan to tow a camper about 50% of the time. I do not punish my trucks! Should I expect a mostly trouble free engine or is it just the luck of the draw?
Old Oct 25, 2010 | 09:28 PM
Zmann's Avatar
Zmann
probably depends on the headstud install and if the really check the heads
Old Oct 25, 2010 | 09:29 PM
cheezit's Avatar
cheezit
so much more depends on correct maintace then anything else.
Old Oct 25, 2010 | 09:33 PM
Zmann's Avatar
Zmann
that
and they are no fun to drive without tunes
Old Oct 25, 2010 | 09:38 PM
HeavyTow's Avatar
HeavyTow
I'm all over the maintenace side of things so I've got that covered. How often does the turbo need to be cleaned and what degree of experience is needed to tackle the project?
Old Oct 25, 2010 | 09:39 PM
cheezit's Avatar
cheezit
when it sticks, a bachelor of science.
Old Oct 25, 2010 | 09:58 PM
HeavyTow's Avatar
HeavyTow
I'm hoping to avoid the sticking issue with the maint.
Old Oct 25, 2010 | 10:22 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
Make sure you have gauges and can monitor ECT/EOT or have the latest flash that keeps an eye on ECT/EOT spread and sets the wrench light if it exceeds 15 degrees differential. Otherwise, you can have undetected oil cooler plugging which eventually leads to EGR cooler failure due to restricted coolant flow to the EGR cooler. Then you have a potential host of more problems. Personnaly, I'd delete the EGR cooler while I was in there doing the HGs. Then you would have have close to a bullet proof motor IMO.
Old Oct 25, 2010 | 10:39 PM
HeavyTow's Avatar
HeavyTow
Please excuse my ignorance but I don't know all of the abbreviations. what is the ECT/EOT?
Old Oct 26, 2010 | 07:30 AM
ljutic ss's Avatar
ljutic ss
Engine coolant tempature/engine oil tempature. ECT/EOT
Old Oct 26, 2010 | 09:16 AM
HeavyTow's Avatar
HeavyTow
Cheezit, I talked to the serv mngr and ARP studs is what he will install for about $400. Also thanks to ljutic for the ECT/EOT info. That was simpe enough, I just wasn't sure if it had to do with exhaust temps.
