transmission
Old Oct 26, 2010 | 10:47 AM
mercracing84's Avatar
mercracing84
transmission
I have a torqshift transmission that wont shift when its warmed up. I can manually shift it, but it will not automaticly shift. Its a 2005. Thanks for the input
Old Oct 26, 2010 | 10:55 AM
desertt5's Avatar
desertt5
Really needs to check it for codes. Most transmission shops can check it. Local here they charge $25 or so to read it and test it.
Old Oct 26, 2010 | 01:29 PM
mercracing84
I'll give that a shot. Thanks
Old Oct 26, 2010 | 01:50 PM
69cj's Avatar
69cj
When was the last service and ext. filter changed? What type of fluid was used? Supposed to be flushed every 30,000 miles and ext. filter changed at the same time. This tranny only uses Mercon SP or LV fluids.
