Head Bolt Question
Old Oct 25, 2010 | 07:00 AM
HeavyTow's Avatar
HeavyTow
Head Bolt Question
Are aftermarket hardened steel head bolts just as good as aftermarket studs?
Old Oct 25, 2010 | 07:03 AM
npccpartsman's Avatar
npccpartsman
That would be hard to know without knowing the tensile strength of both
Old Oct 25, 2010 | 08:05 AM
HeavyTow's Avatar
HeavyTow
Are there any known aftermarket head bolt manufacturers that are best NOT to use?
Old Oct 25, 2010 | 08:47 AM
69cj's Avatar
69cj
If your going with TTY's stick with stock, if studs go with ARP. A lot of money and labor to experiment. This also is an area where you don't want to cut corners to save a buck.
Old Oct 25, 2010 | 11:09 AM
HeavyTow's Avatar
HeavyTow
Actually have my truck in the shop. The service manager is saying if I have a head gasket problem that I need to go back in with aftermarket head bolts. That this would eliminate the stretching problem that occurs with the original equipment head bolts. I don't have any experience dealing with the aftermarket manufacturers & don't want to get stuck with any bad parts.
Old Oct 25, 2010 | 11:28 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Go with the ARP's and be done with it. If you buy them from a dealer, it will be really high tho....they can be bought on the net for between $400-500 I believe.
EDIT: Just saw 'em on ebay for less than 450 shipped.
Old Oct 25, 2010 | 03:34 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
ARP is way to go for aftermarket head bolts or studs. They are well recognized in the automotive industry including gassers and diesels from race applications to standard use applications. Get ARPs and sleep well at night.
Old Oct 25, 2010 | 04:10 PM
hubler13f's Avatar
hubler13f
Brown's Diesel $398. They were the cheapest I could find when I did mine.
Old Oct 25, 2010 | 06:55 PM
HeavyTow's Avatar
HeavyTow
Thanks for the info. I keep seeing ARP as the most commonly recognized studs used here on the site, but didn't know if they had bolts also. Is there any reason to use studs over bolts?
Old Oct 25, 2010 | 07:07 PM
cheezit's Avatar
cheezit
call the guy back and ask him who is making bolts or if he ment studs. IMO the guy selling you the stuff is clueless. but remember the saleing stuff and the guy fixing stuff is normally 2 different people
Old Oct 25, 2010 | 08:31 PM
HeavyTow's Avatar
HeavyTow
It would definately be two different people. I will call and ask if he did mean studs, but he was basicly just recommending that I use aftermarket bolts to get away from the original equipment. He indicated by doing so I would most likely never have any more head gasket problems. I know he can't garuntee this, but I don't intend to modify with tuners or anything to increase hp, I'm just looking to make it as bullet proof as possible.
Old Oct 25, 2010 | 08:42 PM
Zmann's Avatar
Zmann
thx !! I have been shopping
Old Oct 25, 2010 | 08:53 PM
hubler13f's Avatar
hubler13f
Yup, I think they are the best priced out there. Someone on this site told me about them when I was shopping. For some reason they are under the turbo section on their website, but they are there.
cheezit's Avatar
cheezit
gont mine on ebay for $409.
Old Oct 25, 2010 | 09:00 PM
Zmann's Avatar
Zmann
but those were Chinese knock offs
