Tachometer
Old Oct 24, 2010 | 09:05 PM
AndrewDahlin's Avatar
AndrewDahlin
Tachometer
I wish to install a small tachometer in the dash of my truck and was wondering about wiring, good deals, and any mistakes anyone made so I can make completely original mistakes.
Old Oct 24, 2010 | 09:42 PM
ctubutis's Avatar
ctubutis
I think most people here will recommend you add a factory tach from a junkyard but this
can easily happen only on trucks with gauges and not idiot lights.
What kind of instrument cluster do you have?
Old Oct 25, 2010 | 01:19 PM
AndrewDahlin
I am intrested in removing the stock gauges and replacing them with AutoMeter's 5" Old Tyme White II series (with blue light covers) I would like to leave room between the two gauges for a GPS unit as well.
Old Oct 25, 2010 | 05:20 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Still need to know if you have factory gauges or idiot lamps as the wiring is vastly different between them.
Old Oct 25, 2010 | 06:55 PM
6fifty_f1fifty's Avatar
6fifty_f1fifty
Um. Yeah.
What you want to do is make your insturment cluster completley custom. It is going to involve you either splicing into your harness, or running completely new lines for your insturments. There's not much we can tell you except dont plug an ammeter into the wire for an idiot light cause' bad things can happen.
Everything else is going to be up to you, from what you fasion your ic panel out of to what insturments you use... plus you will need an external antenna for your gps if you are going to mount it behind the steering wheel because it won't get a good signal without a clear view of the sky.
Old Oct 28, 2010 | 12:46 AM
AndrewDahlin
I love wiring trucks for some strange reason. and I was auctaly thinking of going with a volt meter instead of an amp meter. And thanks for the advice on the GPS, I grew up out west and these old timey cluster F#?!& they call road systems are a pain for me.
miashley150
13
Aug 22, 2013 11:34 AM
Chris9292
Mar 17, 2008 08:45 PM
WetDog
2004 - 2008 F150
Nov 27, 2006 04:44 PM
aaron59
Aug 27, 2005 05:25 PM
Creep
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jun 25, 2003 10:43 PM
