No Kick Down Power
Old Oct 24, 2010 | 04:50 PM
Rackman's Avatar
Rackman
No Kick Down Power
Help!! Just changed out all the injectors on our 2002 350 Dually with 7.3 and now it runs and starts fine but when you get over 30 MPH and burry the gas pedal there is no Turbo kick in just slowly increases in speed.
Did I forget to hook something back up or have I lost my Turbo now. Thanks for the help!
Old Oct 24, 2010 | 06:01 PM
F350-6's Avatar
F350-6
Does it downshift when you stomp on the skinny pedal? Did you plug the MAP sensor and hose back in?
Old Oct 24, 2010 | 06:15 PM
Visseroth's Avatar
Visseroth
do you have a exhaust gas temp gauge? If so what does it read when you stomp it for a bit.
Old Oct 24, 2010 | 06:17 PM
Rackman's Avatar
Rackman
I am going to check right now. it must be something I overlooked when i put it back together because the problem was not there before the injector change out.
Thanks for Help!
Old Oct 24, 2010 | 06:19 PM
Rackman's Avatar
Rackman
When I stomp the pedal nothing happens. If i hold it down it will gradually accelerate from 40 MPH.
Dont have exhaust temp guage.
Old Oct 24, 2010 | 06:20 PM
Rackman's Avatar
Rackman
Good pickup up to 40 MPH put no passing power.
Old Oct 24, 2010 | 06:25 PM
Visseroth's Avatar
Visseroth
Check your fuel filter. Is it knocking or anything else?
Old Oct 24, 2010 | 06:30 PM
F350-6's Avatar
F350-6
It doesn't down shift when you stomp on it? Did you use rags to keep the intercooler and turbo clean while doing the work and forget to remove one?
Check all the boots on the intercooler pipes and try unplugging the MAP sensor to see if that helps.
Old Oct 24, 2010 | 08:14 PM
Rackman's Avatar
Rackman
No knocking. Just a little shaking at 40 MPH and then no power when you depress the pedal to the floor. Just very slow excelerating.
Old Oct 24, 2010 | 08:16 PM
Rackman's Avatar
Rackman
Going to check all hoses and pipes in morning. thanks for the help!!
Old Oct 24, 2010 | 10:38 PM
Deluxe06's Avatar
Deluxe06
4000 rounds a min
Are you hearing a loud whoooosing sound when excelerating? if so then check your EBPV rod to make shure the clip didn't come off. Or to see if you didn't hook it up.
4X4HB
Jul 23, 2013 03:00 PM
FordTruckEnthusaist
Aug 10, 2012 07:42 PM
supperman2k
Aug 9, 2011 12:41 AM
Mr. Finch
Jun 9, 2010 08:47 AM
Big_Man_Brad
18
Aug 15, 2007 10:12 PM
