When does your turbo kick in!!!!!!
Old Aug 13, 2007 | 07:29 PM
Big_Man_Brad's Avatar
Big_Man_Brad
I was wondering when everybodys turbo kicks in.. Mine won't kick in untill 35 miles and hour when i step on it...
Old Aug 13, 2007 | 07:58 PM
WA.Ranger's Avatar
WA.Ranger
WOW!!! Mine spools up shortly after I romp on it.
Old Aug 13, 2007 | 08:06 PM
John311t's Avatar
John311t
I dont know about speed wise(mph reading), but it usally happens when the foot goes to the floor, it happens a sec or two after that.
I think you have a massive boost leak or exhaust leak. Is your mileage very poor?
Old Aug 13, 2007 | 08:07 PM
VQ2Fast4U's Avatar
VQ2Fast4U
I have a laggy 1.15 exhaust housing, but it starts to get going at about 10psi. Depending on speed 2200rpm is when it starts to light up.
Old Aug 13, 2007 | 09:00 PM
CampSpringsJohn's Avatar
CampSpringsJohn
My turbo is working all the time,,,,,,,,,. Anyhow, mine seems to really get going at around 2000rpm's. If you're not used to a turbo engine, they will do more when the engine rev's up. In other words, at 2000rpm's, you will have more boost than 1000rpm's. The more boost, the more power. I heard Gale Banks say that a diesel engine will gain 7% in horsepower for every 1 pound of boost pressure. There is always a little bit of lag time from when you hit the pedal and when the engine catches up with your foot.
Old Aug 14, 2007 | 12:28 AM
TwelveAlpha's Avatar
TwelveAlpha
Is it safe to assume you still have the stock turbo in there? IIRC, that took a little bit to get lit, but not much. 35mph . . . that makes me think leaks. The one I have now, it spins almost all the time. Pretty much any time not just idling, and it spools fast. It'll go nothing to pegged in about a second on the gauge, and even though its different, its not THAT different.
Do you have gauges or are you judging by ear?
Old Aug 14, 2007 | 09:11 AM
Big_Man_Brad
Yes i do have gauges..When i stomp on it nothing happens till i reach 35 mph and than the turbo kicks in.. I barely can accelerate in traffic.. .HAHAHA....
Old Aug 14, 2007 | 09:31 AM
F250_'s Avatar
F250_
I start to hear a little whistle every time I push past 2000 rpm.
Old Aug 14, 2007 | 11:04 AM
CampSpringsJohn
What can you tell us about your truck? What year? What engine? How many miles? An exhaust leak around the turbo where the exhaust comes in to the turbo will cause them to not work properly. Also, a leak in the air induction system will cause them to not work right too. Are the bearings possibly going out in the turbo? Look for signs of oil between the turbo and the air to air cooler, and the exhaust.
Old Aug 14, 2007 | 01:29 PM
Big_Man_Brad
it a 2000 f-250 crew cab short box with 237,000 miles and it has the 7.3 liter engine... ok i'll look and try that and see if there is any leaking around there...
thanks for your help guys
Old Aug 14, 2007 | 01:53 PM
CampSpringsJohn
Possible air filter plugged up? Something blocking the air intake? Just throwing ideas out ther for you to check.
Old Aug 14, 2007 | 04:26 PM
TraderJ's Avatar
TraderJ
Mine starts spooling right away....probably 10 mph or less...not huge boost but it will hit 2-3 psi as soon as i press the pedal
Old Aug 14, 2007 | 04:36 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I too gotta say it doesn't take much to get mine going. Just made a beer run in the 80e and it gets going pretty quick with moderate pedal input.
Old Aug 14, 2007 | 06:10 PM
lukecline's Avatar
lukecline
mine starts to spool @ around 2000 rpms and by 2100 rpms its on like donkey kong.
Old Aug 14, 2007 | 06:33 PM
UT1Rusty's Avatar
UT1Rusty
I just put my gauges in and this is my first PSD. Depending on how much throttle I give it I see 2 at little throttle and 18 when I stand on it. As far as whistle goes I have a loud whistle as soon as I give it a little throttle.
