Sponsored by: Auxito
Separating inner tie rod end without using pickle fork?
Old Oct 24, 2010 | 03:00 PM
paker's Avatar
paker
97 RWD
Does anyone know how to separate INNER tie rod end without using the pickle fork?
I would like to reuse it and want to avoid using pickle fork.
In his how-to RACERGUY hammered the side of the joint for ball joints and outer tie rod, but didn't mention INNER.
Thanks.
Old Oct 24, 2010 | 03:03 PM
Alex7191's Avatar
Alex7191
really the only way to get the inners off is to use a pitman arm puller
Old Oct 24, 2010 | 03:07 PM
Alex7191's Avatar
Alex7191
well, tie rod end puller i guess. if you have an autozone or oriellys near they will loan them to you. Dont try buying one form harbor freight.. it will break. ask me how i know lol
pickle fork or puller you're still probably gonna mess up the boots.
Old Oct 24, 2010 | 07:16 PM
paker's Avatar
paker
Thanks. Does PB Blaster help?
Has anyone been able to separate inner tie rod end with Pitman puller?
Old Oct 24, 2010 | 10:35 PM
Lime1GT's Avatar
Lime1GT
I haven't tried with my 02, but sometimes you can separate them by using pressure of a prybar between the tie-rod and drag link or frame and giving the drag link a sharp blow on the side with a large hammer right where the tie-rod goes through. Works better with two people. If you try this, back the tie-rod nut off but leave it attached to the stud by a few threads, so that when things let go, pieces don't go flying everywhere.
Old Oct 25, 2010 | 12:18 PM
GammaDriver's Avatar
GammaDriver
If you really want it off to change the outer, spend the $21 and buy a cheap new inner. $43 for a MOOG locally, though one auto parts chain always want to charge $20 more for the same MOOG part.
You could try hammers the center-link a bit, but that didn't do it for mine.
Why save an old TRE?
I know one thing - don't hammer directly on the threaded post to try to hammer it straight out... I tried that and it mushroomed the threaded part badly, making it nearly un-uasable if one were to try and save that TRE.
Old Oct 25, 2010 | 12:19 PM
GammaDriver
You could try hammering the center-link a bit, but that didn't do it for mine.
Part of the decision to go change more than I had to change was for overall speed and ease. I bought two of the threaded sleeves that connected the TRE's just in case - and boy am I glad I did. I could have saved $15, or what-ever they cost and played with trying to get the old TRE's off of them for a very long time, or I could have new sleeves at the ready to speed my job up - which I did. I ended up actually only needing one of them (one side of the truck would not easily come apart, and it was either PB'ing it and buying a vice AND setting the vice up, or just using a new one) - so I took one back.
Throwing four new TRE's into sleeves I could work with easily was worth the cost vs. more tools and time, and the chance that the truck would be out of commission into Monday - and that was on a budget that I was barely able to keep feeding myself rice & beans (was out of work). part of it, though, was that it was a northern truck, so rusted together parts and the possibility that the old sleeve that was stuck wouldn't work anyway were a factor in putting out a little extra money to just get the job done.
Old Oct 26, 2010 | 06:55 PM
paker's Avatar
paker
Thanks for the suggestions. I cannot work on the truck now. I will report back in a few weeks.
Old Oct 26, 2010 | 07:22 PM
GammaDriver
That's awesome - if you have that much time to work on it, then yeah, you can play around and try to save parts.
The angle I was coming from was that it was your daily driver. With mine, anything that I do needs to have the truck running again by Sunday night.
Old Oct 26, 2010 | 07:52 PM
Speedjester's Avatar
Speedjester
Tie rod end puller. Will not damage boot as long as you don't pinch the boot.
Old Oct 27, 2010 | 10:52 AM
paker's Avatar
paker
Originally Posted by Alex7191
I tried it without success. I wish the opening between the lips was a little narrower. I sprayed PB Blaster a couple of nights ago. I will try again in a few days.
The truck is not my daily driver. Time is on my side.
Thanks for tips.
Old Oct 27, 2010 | 12:06 PM
GammaDriver
Thanks for tips.
Just like pickle forks are different sizes, surely Tie Rod pullers come in different sizes as well to get closer in on smaller TRE's?
Racerguy
1997 - 2003 F150
214
Jun 10, 2025 07:58 AM
Bon
13
Aug 3, 2016 10:06 PM
testlight
30
May 17, 2016 07:35 PM
1215
Escape & Escape Hybrid
Feb 29, 2016 05:18 PM
4.9LOldFordTruck
Jan 20, 2016 04:38 PM
