no start after reassemble
Old Oct 24, 2010 | 08:25 AM
1995f25013's Avatar
1995f25013
i put my truck back together from replacing lower intake gasket. i went to turn it on it ran for roughly ten seconds. then it shut off. i checked the plug wiring and plug wires on 3 and 4 were switched. fixed that tried to start again and there no start just cranks over. what are possible causes the distributer was out and put back in at same spot.
Old Oct 24, 2010 | 09:29 AM
skyfox10's Avatar
skyfox10
ok, I would say stop and pull codes.
I say this because of an 87 Celica I had that did that when I forgot to plug a sensor back in. I would say pull the codes and see if anything comes up. What would be better yet is if you could do a KOEO test at this point.
This also seems likely since you had to have all of the intake stuff apart which is riddled with all sorts of electronics.
Old Oct 24, 2010 | 12:49 PM
ymeski56's Avatar
ymeski56
Der Postmeister
I say this because os on 87 celica I had that did that when I forgot to plug a sensor back in. I would say pull the codes and see if anything comes up. What would be better yet is if you could to a KOEO test at this point.
Good call. A KOEO scan will usually tell you what's missing to start, sensor wise.
Old Oct 24, 2010 | 01:02 PM
Old93junk's Avatar
Old93junk
Any time you remove the dist, you should go back to #1 TDC.......just dropping it back in the "same spot" may put you a tooth off one direction or the other.
Old Oct 24, 2010 | 07:46 PM
skyfox10's Avatar
skyfox10
anyone know how many teeth are on a dist?
Old Oct 24, 2010 | 09:43 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Less than a plethora.
Old Oct 28, 2010 | 10:18 AM
1995f25013's Avatar
1995f25013
thanks all for the replies i checked out everything you all have said and it turns out some how the distributor rotor wasnt seated properly and it popped off some how. how ever put it back on and it was good to go. thankyou for all the replies
Old Oct 28, 2010 | 10:23 AM
ymeski56's Avatar
ymeski56
Der Postmeister
Mechanic(alish) error.
scottddove
23
Apr 15, 2024 11:06 PM
URDADDY
Feb 23, 2012 10:31 PM
firefighter72
Computer Chips & Tuners
Nov 9, 2011 09:14 AM
remmers
Sep 10, 2004 11:35 AM
MitchPeters
16
Mar 12, 2003 07:03 AM
