Aerostar Ford Aerostar
A4LD rebuild
Old Oct 23, 2010 | 07:15 PM
cgbier's Avatar
cgbier
A4LD rebuild
I'm about to order the parts for the transmission overhaul.
Is this gonna work?
Atc-Pro-King/Automatic Transmission Rebuild Kit (KS-97) | Automatic Transmission Rebuild Kit | 1995 Ford Aerostar 2WD 6 Cylinders U 3.0L MFI | AutoZone.com
And this TC?
Dacco/Transmission Torque Converter (A4LD) | Transmission Torque Converter | 1995 Ford Aerostar 2WD 6 Cylinders U 3.0L MFI | AutoZone.com
Any other sources?
Sorry, I have no experience with A/T or American cars (but working on it )
Old Oct 24, 2010 | 02:19 AM
96_4wdr's Avatar
96_4wdr
i'd put in a shift kit also
A4LD Performance Transmission and Parts from PATC, A4LD
A4LD, Valve body kits, Bulkpart transmission parts
i'd put in new pump gears
A4LD, Pumps, Bulkpart transmission parts
and new servo pistons seals break down harden and wear out
A4LD, Servos & Accumulators, Bulkpart transmission parts
and check the A4LD 6 bolt crankshaft spacer, they often are broken
get the upgrade from the first link
new vac. modulator
Dacco TCs are good, stay away from the eGay stuff
DIYer extensive guide with pics.
My A4LD transmission rebuild diary - Ford Explorer Ranger Enthusiasts "Serious Explorations"®
Old Oct 24, 2010 | 07:11 AM
cgbier's Avatar
cgbier
Thanks a lot for the answer.
I've seen (and bookmarked) your log... it was what brought me to this great site.
Old Oct 25, 2010 | 11:03 AM
taurus8's Avatar
taurus8
...and since you're getting greasy, add another cooler to make it the only rebuild you'll ever do...mine with a rebuild and a new cooler sees 120F heat, towing a trailer and never falters.
Old Oct 26, 2010 | 04:05 AM
96_4wdr's Avatar
96_4wdr
what taurus said^
plate and fin ATF coolers are the best. tube/fin have too much ATF flow restriction, starves the tranny of lube. I bypassed my in radiator tank cooler and just run with one huge plate fin
even improved the shifting
no overheating even towing 4000 lbs +
Old Oct 26, 2010 | 09:15 AM
KhanTyranitar's Avatar
KhanTyranitar
The tube and fin coolers don't create flow restriction, they just don't efficiently get rid of head unless they are rather large. The plate type coolers are far more efficient. I posted a picture of my setup in my "Major Repairs and Upgrades" post. The coolers are small but very effective at eliminating heat. I'm running two of the B&M Supercoolers. I use one for the trans and the other for power steering. The power steering one is because they way I have mine set up I simply don't have room for the original trans cooler to be used for the power steering. But two B&M supercoolers fit very nicely. I had to do mine the way I did because I have a pusher fan on the front of my condenser. The cooler is way overkill on the power steering.
hateme
17
Oct 19, 2014 09:59 AM
Mi-Cyn
Aug 26, 2014 08:53 AM
powerstroker100
Jun 1, 2014 06:48 PM
